-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Crankshaft Pulley Replacement (http://forums.pelicanparts.com/mini-discussion-forum/975724-question-crankshaft-pulley-replacement.html)
martinroger (guest) 10-29-2017 05:34 AM
Hey, I have a non-S 2002 Cooper. Can the harmonic dampener be replaced by the 2004 model rather than the current three-spokes layout ?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Crankshaft Pulley Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-29-2017 05:34 AM
Good question, I have not done or heard of that swap. The engine block and crank are the same. SO - if the pulley diameter is the same, it should be OK.
- Nick
Luccia at Pelican Parts 11-03-2017 07:44 AM
Why not stick with what you've got? We have your stock one here: 2002 Mini Cooper Base Hatchback - Engine Miscellaneous - Page 1
