Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
I have a 2008 mini cooper s that has an oil leak in the area of the crankshaft seal, but the back of the pulley is dry and the seal shows no signs of leaking. I resealed the pan earlier and replaced the crankshaft seal earlier, but still dripping oil. It looks like it is leaking up higher than the pan and dripping down. Any other ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Leak Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:17 AM
Nick at Pelican Parts's Avatar
Timing chain bolt seals?
- Nick
Administrator
Luccia at Pelican Parts's Avatar
clean off all areas with oil completely. keep an eye on it for the next week to see if you can pin-point the source.
Old 11-15-2017, 09:34 AM
