Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Matty (guest)
Guest
Posts: n/a
I�ve got an error message showing 2EE2 Coolant temperature sensor plausibility: signal constant. No check engine light at the moment. Does something need attention? I recently changed the exhaust solenoid to get rid of error 2845 and the 2EE2 was there before as well.
I�ve got a Mini Cooper r56. Any tips would be great
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 06:18 AM
Nick at Pelican Parts's Avatar
Could be an issue with the sensor or thermostat. I would check engine warm up time, if Ok, replace the sensor.
- Nick
