Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
R56 Mini Cooper S (2007) starter replaced/intake man removed - now SPUTTERING ENGINE
plz help guys.
I removed the intake manifold to replace the starter which had a bad solenoid. Meanwhile, the car cranks and starts perfect now thx to the new starter - however, the engine won't stay on, it sputters between 500-1000rpms and then shuts off. If i throttle full upon starting it, it will go to 4000rpm max and then die completely.
I have checked all my wiring/hoses that i touched a million times, and taken the intake man off/on probably 10x now, cannot seem to fig it out!!!
No Check engine codes showing up either.
Old 02-13-2018, 07:26 PM
anyone?
Old 02-15-2018, 12:47 PM
New to the site ...i may have a similar problem ...did you find the culprit?
Thanks, ASC..Auto Services Co
Old 05-22-2018, 03:11 PM
Administrator
Luccia at Pelican Parts's Avatar
Did you smoke test the vehicle to make sure there aren't any vacuum leaks?
Old 05-28-2018, 10:51 AM
Sure sounds like a vacuum leak. I assume you replaced the gaskets.
I just came in from the garage 10 minutes ago. I was trying to replace the starter on my '08 but I can't get the intake manifold off. I tried to follow Nick's instructions and the manifold is loose but won't slide off. I may have missed a fastener. Any ideas?
Old 06-19-2018, 02:13 PM
Administrator
Did you remove the bolt from figure #14 here? https://www.pelicanparts.com/techarticles/MINI_R56/85-FUEL-Turbocharged_Engine_Intake_Manifold_Replacement/85-FUEL-Turbocharged_Engine_Intake_Manifold_Replacement.ht m
Also, make sure there aren't electrical clips holding the harness to the intake and the bolt under the throttle body.
Old 06-25-2018, 04:54 PM
