CVCC. And with a carburetor!!
CVCC used a rich mixture on one side of a perforated barrier (which had its own valve) and a lean mixture on the other side. The rich mixture is used to ignite the lean mixture.
Mazda is using a small rich mixture just in front of the spark plug to compress the remaining lean mixture without a barrier. |
I need pictures:
<iframe width="914" height="514" src="https://www.youtube.com/embed/PT2Mt-tkJ_4" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe> Mazda's SPCCI compression engine: Here's how it works https://www.mazdausa.com/why-mazda/skyactiv |
I would think that any gains that an opposed piston engine would be able to muster from more efficiently capturing combustion energy would be lost from more complicated mechanicals (two crankshafts, for example).
The first time I went through training on the SH-60 was in 1984...very rudimentary slides but lots of words to describe systems, which we were tested on. I of course memorized how everything worked but really didn't understand the more esoteric systems, like the fuel control system. Going back through a shortened syllabus in 1994, they had computer animations of all the systems and it was the first time I really understood the complex interactions. I get what Mazda is doing and now understand the concept. |
Matt, do you have a diagram? I can't picture how you can have horizontally opposed cylinders with only one crankshaft.
Infiniti has been selling cars with it's variable compression engine for a year now.
http://forums.pelicanparts.com/off-topic-discussions/944574-variable-compression-engines.html |
Mazda is doing interesting work here combining the spark ignition and diesel ICE techs ... compress the fuel to almost the point of self ignition, inject a tad more into the vortex and ignite the center, creating a compression wave which ignites the rest of the fuel ... more power, more torque at lower rpm, improved efficiency.
https://spectrum.ieee.org/transportation/efficiency/mazdas-new-skyactivx-engine-gives-new-life-to-internal-combustion |
I friend of mine has and drives his 1999 Honda Insight as his commuter vehicle.
<iframe width="1054" height="593" src="https://www.youtube.com/embed/EzG2bQK2Ygs" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> He get 60 MPH even today. The battery pack is dead. He has to pull the fuse to the system to get it to start and run, and withing a few minutes the error lights come back on, so he is running on just gasoline. He plans to maybe pull the battery pack and guys on the internet have figured out how to test each cell of the pack, and replace the bad cells. He said it is a slow and tedious process. He said people ask him more questions about it than any of his Porsches. Many people ask if he built the car himself, as they have never seen one like it. |
There are very competitive males I know that track these things, and are all out to beat eachother. The end result is they pay attention to their driving, look ahead, and do their best to maintain momentum without giving it up. |
Anything with a turbo is variable compression... |
repost: selectable squish
http://forums.pelicanparts.com/uploa...1574962080.jpg Raising an engine’s compression ratio improves fuel efficiency during low-load operation, but it can also lead to catastrophic detonation when maximum power is requested. Engineers have long sought to navigate this challenge with a variable-compression-ratio engine, and Infiniti promises to implement its solution in early 2018 with a complex system of links in the crankcase. There’s more than one way to skin this cat, though. German powertrain engineering company FEV proposes a piston wrist pin that passes through an eccentric bushing at the top of the connecting rod. As the bushing rotates, the piston moves vertically relative to the rod, in turn adjusting the compression ratio. The position of the bushing is determined passively by a pair of miniature pistons inside the connecting rod that rotate the cam in reaction to combustion and inertia forces. FEV’s 1.7-liter turbocharged inline-four demonstrator can adjust its compression ratio from 8.8:1 to 12.0:1 in 0.2 to 0.6 second. |
I bet that puppy ain't cheap.
| All times are GMT -8. The time now is 05:25 AM. |
