-   -   Mazda's engine development (http://forums.pelicanparts.com/off-topic-discussions/1003643-mazdas-engine-development.html)
Tervuren 11-28-2019 02:01 PM
Originally Posted by unclebilly (Post 10672616)
Wasn’t Porsche the first to market a variable compression spark ignition gasoline fueled car? Sometime in 1975???
Anything with a turbo is variable compression...
I think he meant compression ratio, which will generally be the difference in the combustion chamber capacity from BDC to TDC.
stevej37 11-28-2019 02:59 PM
Originally Posted by Sooner or later (Post 10672675)
I bet that puppy ain't cheap.
Probably right! I wish the article would have gone further and explained what controls the miniature pistons that rotate the cam. Oil pressure? Electronic?
island911 11-28-2019 04:06 PM
Originally Posted by stevej37 (Post 10672658)
repost: selectable squish
http://forums.pelicanparts.com/uploa...1574962080.jpg
snip... nline-four demonstrator can adjust its compression ratio from 8.8:1 to 12.0:1 in 0.2 to 0.6 second.
Oil pressure. Note the long slot in the main.
edit: internal passages must feed (selective) pressure up from the main bearing.
I can see how this could hold pressure (like a hydraulic valve) but I'm not seeing the control side.
Sooner or later 11-28-2019 05:18 PM
Video at link.
Says it changes due to combustion and inertia forces.
https://vcr.fev.com
petrolhead611 11-29-2019 12:04 AM
Atkinson cycle does it by opening the inlet valve again when it would be shut in an Otto cycle
island911 11-29-2019 11:43 AM
per WIkipedia
In the late 20th century, the term "Atkinson cycle" began to be used to describe a modified Otto-cycle engine—in which the intake valve is held open longer than normal, allowing a reverse flow of intake air into the intake manifold. This "simulated" Atkinson cycle is most notably used in the Toyota 1NZ-FXE engine from the early Prius.
