White and Nerdy
Tervuren's Avatar
Originally Posted by unclebilly View Post
Wasn’t Porsche the first to market a variable compression spark ignition gasoline fueled car? Sometime in 1975???
Anything with a turbo is variable compression...
I think he meant compression ratio, which will generally be the difference in the combustion chamber capacity from BDC to TDC.
Old 11-28-2019, 02:01 PM
Originally Posted by Sooner or later View Post
I bet that puppy ain't cheap.
Probably right! I wish the article would have gone further and explained what controls the miniature pistons that rotate the cam. Oil pressure? Electronic?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 11-28-2019, 02:59 PM
Information Junky
island911's Avatar
repost: selectable squish
snip... nline-four demonstrator can adjust its compression ratio from 8.8:1 to 12.0:1 in 0.2 to 0.6 second.
Oil pressure. Note the long slot in the main.
edit: internal passages must feed (selective) pressure up from the main bearing.
I can see how this could hold pressure (like a hydraulic valve) but I'm not seeing the control side.
Old 11-28-2019, 04:06 PM
Video at link.
Says it changes due to combustion and inertia forces.
https://vcr.fev.com
Old 11-28-2019, 05:18 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Atkinson cycle does it by opening the inlet valve again when it would be shut in an Otto cycle
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 11-29-2019, 12:04 AM
Information Junky
island911's Avatar
per WIkipedia
In the late 20th century, the term "Atkinson cycle" began to be used to describe a modified Otto-cycle engine—in which the intake valve is held open longer than normal, allowing a reverse flow of intake air into the intake manifold. This "simulated" Atkinson cycle is most notably used in the Toyota 1NZ-FXE engine from the early Prius.
Old 11-29-2019, 11:43 AM
