I think Tom is a first time buyer? What might be trivial for some of us (not for me), is probably not the way to go for a novice.....with a life :). Unless this board guides his way....seriously!
One thing to consider is that builders generally do not provide adequate foundations, or any serious engineering into their design, so I would always be wary of houses that are perched on sloping lots and also any house on soil that has a high clay content, particularly in a climate like Texas, or you have hot dry summers.
Even though the brick on that house is a veneer, if it been built properly you would never see a problem like that. My house was built 45 years ago and doesn't have a single crack anywhere in the brick façade. |
There have to be other houses around without the issue in Wolf-Boy's (Wolf-Man now?) price range. Hey Tom, we need to get out for an Astros game! SmileWavy |
Here you go. All brick imprints are supposed to face inwards so they cannot be seen. This was a poor job. And the installation of the windows was poor as well.
RUN, don't walk, from this house. Mold mold mold mold mold http://forums.pelicanparts.com/uploa...1538745096.jpg |
In addition to your mold fears, I'll add that water intrusion will also destroy the integrity of any wood structure if enough time elapses. Cracks of that size can allow significant water entry. Run, Forrest, run... |
Agree with others:
- Brick appears inadequately supported, and/or wood beam and/or foundation has settled. Look for cracks/bowing/sloping on the slab in the garage. - There will be water intrusion. But the level of damage is TBD and that would be my bigger concern -- is there structural rot in the wall/window/roof/ceiling? Brick cracks are actually pretty easy to repair (assuming you've got adequate support below). Water damage is cancer. If you (or the seller) decides to fix it and you need a "brick guy," PM me as I can make a recommendation of one I used -- I've successfully had worse brick cracks repaired and it looks good and has held up great many years later. But I already owned the problem -- if the house you're looking at isn't otherwise special (or deeply discounted), I'd keep looking for one that's better built/maintained. |
Run, don't walk, away from this one!
I'm a structural engineer (but I didn't stay at a Holiday Inn last night) and investigated 1000s of these type problems over the years. It appears, the wall with the window is set back further than the front garage wall, right? So there has to be some sort of beam just above the garage ceiling and directly below that wall that span across the garage. It will not be visible without cutting the drywall garage ceiling. That beam is the likely problem - it is probably a double LVL or maybe a glulam. If it is only a double or triple 2x12 it is surely undersized and improperly nailed and is a sign of poor quality construction that may also be present in other hidden areas of the home. If the beam is OK, then it's the lintel directly supporting the brick like previously mentioned.
These LVL beams (and even steel) are often improperly sized by the guy at the lumberyard counter from a spec book, and not understanding that there is a significant amount of deflection (sag) allowed when the beam is used for a floor or roof (which is what the standard charts are for). Obviously, brick cannot flex and a much stiffer beam is required. Hopefully, your engineer brings a drywall saw, or at least , a borescope and drill to see what's above the garage ceiling. This is not a foundation problem. Nothing is going to collapse. It's sort of a nuisance type failure but will be a constant leakage source. |
As an architect, I am in agreement with the group here. While this issue may be fixable from an aesthetic standpoint, given what appears to be open joints, there is the potential for mold in the wall. Not with standing that the brick is just a decorative element, given the sloppiness of the brick install it is likely there are holes in the underlying water proof membrane that would allow moisture in the wall. The only way to determine that is to pull the finish from the inside, remove the insulation and look at the sheathing.
If there are other houses in the area that are better built, then go there. These problems are solvable, you just need to go into understand the full extent of what repairs might be and requesting reasonable accommodation to determine if a problem exists. If you pull the drywall interior finish, say a 2 foot square and find no mold, the only harm is a patch and some paint. Sort of like the PPI on my clone. Inspector thought there was damage to second gear synchros, so we negotiated pulling the motor and trans. He paid for that, and if there was no damage, then that was the only concession he made. |
I DO NOT LIKE STICK BUILT HOUSES [siding] :rolleyes: esp in hurricane strike areas after ANDREW came thru a fair number of upper stick build walls blew off allowing the homes to be destroyed or severely damaged does that house have upper siding like the one on each side do as winds are more powerful higher up our fake brick houses are over a CBS walls here and the brick is attached to the wall not a free spaced single layer |
no tie to the stick built wall at all ? so in 100 mph + winds the wall/facing will shake and break my 40's built CBS OLD HOUSE SHOOK AT 100MPH BUT DID NOT BREAK it was a small house but built with 4x8 roof beams [that were a full 4'' by 8'' old style] and roof was t&g planks not ply my current house in the ANDREW eyewall area cracked a few CBS joints but held likely from impacts of flying stuff it was built in 1955 very few stick build homes survived in the eyewall esp the siding on second floors I would look for older homes built of CBS by union labor in the 50/60's too many short cuts on new homes today I really do NOT modern building standards and cheap unskilled labor used today |
Send me a text and let me know where, I'll come look with you if I can. Although this may be a house to pass on. |
When they built our house with a brick veneer, they used sheet metal anchors. Not sure how strong they really are though.
http://forums.pelicanparts.com/uploa...1538767845.jpg |
how many anchors are used by code ?
If they used dimensional lumber to make their own support for that wall, something I see all the time (especially in headers) that will have shrunk since the house was built and their 2x12s might only be 11 inches wide now, as opposed to the 11.5 inches they likely were when installed. That's enough shrinkage to cause that problem.
I'd find another house, that one will have more problems than just the one you see now. |
Your answer will guide my follow up post. *edit* Heck with it. If she is your SO, nice job. If she is the realtor, nice job. https://i0.kym-cdn.com/photos/images...0/154/820.jpeg |
| All times are GMT -8. The time now is 06:20 AM. |
