-   -   Is changing the rear sprocket on a motorcycle a bad idea? (http://forums.pelicanparts.com/off-topic-discussions/1010638-changing-rear-sprocket-motorcycle-bad-idea.html)
vash 10-17-2018 05:21 PM
My bike. triumph 800xc
In sixth gear, it feels like I need a seventh gear. Motoring along at 70-75, it revs up there. (Embarrassed I forget the actual RPM; I’ll note it tomorrow)
Fuel mileage is also fairly bad on this thing. 30?
I was just Revving my happy butt home when I tried to switch into 7th. Got me thinking; do people tailor their gear ratios?
Just wondering.
dlockhart 10-17-2018 05:35 PM
Just wondering.
Yes. Set up for the task at hand. On my atm 640 adv I usually take a tooth off the front for off road adv fun.
DerkPerk 10-17-2018 05:50 PM
Like dlockhart said. Not a big deal to “re gear”. A tooth on the front sprocket will make a bigger change than just a single tooth in the rear.
FPB111 10-17-2018 05:56 PM
I loosely use “One tooth on the front equals three on the rear”
ckelly78z 10-17-2018 06:02 PM
Changing 1 tooth on the front sprocket will generally be the same as a 6 tooth change on the rear....usually a 6-1 ratio. Going smaller on the rear sprocket will give you slightly worse acceleration, but a better top speed (lower RPM at 60) while going 1 tooth bigger has the opposite effect.
Eric Coffey 10-17-2018 06:06 PM
Just wondering.
Most modern bikes have a top end that is WELL above legal limits, so it's a pretty common mod to go up a few in the rear (and/or down 1 or 2 in front) to swing the balance towards better acceleration vs. higher top-end.
Better for hooning in many cases too. :cool:
If you bought the bike used there is a good chance the PO could have done so already. Just count the teeth (or find the "T" number stamp) and compare to stock sprocket specs.
vash 10-17-2018 06:08 PM
I’m staring at mtn-bike now....
Go bigger six in the rear. Or smaller one in the front. Got it.
Eric Coffey 10-17-2018 06:24 PM
If you want taller gearing for better top-end/mpg, then you would go bigger (more teeth) in front and/or smaller (less teeth) in the rear. ;)
scotricker 10-17-2018 06:35 PM
No, no, no... wait...
What you have just described will make your bike feel like it accelerates faster, but will produce even MORE revs at cruising speeds.
In order to get your cruise RPMs down, you will want to go one bigger front, and/or a few teeth less on the back. Look at a 10 speed bicycle, and you'll see the idea.
id10t 10-17-2018 06:40 PM
In the halcyon days of 356 and early 911/912 racing, there were gearing set ups known as "air port gears"
http://forums.pelicanparts.com/porsche-911-technical-forum/55643-airport-gears.html
motley911 10-17-2018 06:41 PM
^^^ this.....
Another thing you need to consider is chain length. Removing ~6 teeth from the rear sprocket will result in the rear wheel needing to be moved out enough to take up the resulting chain slack - and you may run out of adjustment. This is why most folks just go up or down one tooth in the front, as it doesn't change the chain length significantly.
vash 10-17-2018 07:16 PM
Duh! I got flipped around. Haha.
71T Targa 10-17-2018 07:57 PM
https://advrider.com/f/threads/tiger-800xc-17t-front-sprocket-love-it.1023024/
A ringing endorsement to going one up in the front.
Jeff Higgins 10-17-2018 07:58 PM
A lot of bikes don't have clearance for bigger countershaft sprockets. 15 teeth is a pretty standard size for these, but going to 16 might have the chain rubbing the cases.
A lot of bikes are geared 15/45, or forty something anyway. So, yes, one tooth on the front (countershaft) sprocket equals about three teeth on the rear sprocket. That makes it really tempting to change the front for an easy, no need to adjust chain length change in gearing. Just make sure you check clearance between the chain and cases.
herr_oberst 10-17-2018 08:00 PM
Originally Posted by Jeff Higgins (Post 10219362)
..So, yes, one tooth on the front (countershaft) sprocket equals about one tooth on the rear sprocket. That makes it really tempting to change the front for an easy, no need to adjust chain length change in gearing. Just make sure you check clearance between the chain and cases.
I always thought it was one front, 3 (or 4) rear? Maybe I had bad info, but that stuck with me since I was a kid...
Eric Coffey 10-17-2018 08:12 PM
There you go Vash. Swap in a 17T in the front and you should be GTG for what you are looking to accomplish (or at least further in that direction).
Also, a side benefit of going bigger in the front is that increasing the radius will reduce chain wear a bit.
javadog 10-17-2018 08:22 PM
It's fairly simple math to calculate the effective gearing change. Figure out what rpm's you're turning at your cruising speed, decide what you'd rather that be and work from there. Let us know what the numbers we're talking about and we can give you pointers on a few things.
I don't know what kind of mileage you have on your bike, but if it's enough miles that you've got noticeable wear on either the chain or the sprockets, You should probably change all three items at once.
Evans, Marv 10-17-2018 09:28 PM
Start out with one more tooth on the front sprocket. You should be able to calculate the difference in RPMs at cruising speed.
