Leaking Trans Hose Cause
my 2012 tsx wagon has a weeping trans filter hose. Is this due to the clamps or the hose getting dried out? Was wondering if different hose clamps might fix the issue.
http://forums.pelicanparts.com/uploa...1549156346.jpg TIA! SmileWavy |
Squeeze the rubber. Is it brittle/hard
That style relies on metal memory. Also notice the hose is not fully on.
You may be able to clean and re-seat it but probably not. Could the filter need changing, is clogged, and thus incoming line pressure is too high? I think the smooth ones are generally better than the standard screw type if you can find it in a tuner or specialty store. http://forums.pelicanparts.com/uploa...1549161666.jpg |
Spring clamps are the preferred hardware for this application because they generate very even clamping force. I would replace the hose and clamps as it is probably aged out.
| All times are GMT -8. The time now is 11:50 AM. |
