Grip It & Rip It
Leaking Trans Hose Cause
my 2012 tsx wagon has a weeping trans filter hose. Is this due to the clamps or the hose getting dried out? Was wondering if different hose clamps might fix the issue.
![]() TIA!
82 911SC (sold) |
Squeeze the rubber. Is it brittle/hard
dolor et pavor Copyright |
You do not have permissi
That style relies on metal memory. Also notice the hose is not fully on.
You may be able to clean and re-seat it but probably not. Could the filter need changing, is clogged, and thus incoming line pressure is too high? I think the smooth ones are generally better than the standard screw type if you can find it in a tuner or specialty store.
Spring clamps are the preferred hardware for this application because they generate very even clamping force. I would replace the hose and clamps as it is probably aged out.
2021 Cayman GTS 4.0L 2020 Macan (dog hauler) |
