Almost Banned Once
sc_rufctr's Avatar
Flushing power steering fluid the easy way.
What did we do before YouTube?
I just completed this on my brothers truck.
It's a really straight forward way of flushing your power steering fluid!
And it worked perfectly.
- Peter
Old 02-03-2019, 02:15 AM
Team California
speeder's Avatar
I think that he only flushed the reservoir. He also used the wrong oil, '90s GM truck would be DEX/Mercron red ATF.
Why is he afraid to start the engine and do it right? He has so many of the elements of the job there.
Denis
Old 02-03-2019, 08:58 AM
Almost Banned Once
sc_rufctr's Avatar
Denis, I've always done it with the engine running but I can now confirm this method works perfectly.
The hardest part was getting the low pressure hose off the return pipe.
At 6.30 you can see the fluid is completely "fresh". He topped off the reservoir as the dirty fluid was pumped out.
- Peter
Old 02-03-2019, 04:36 PM
Control Group
Tobra's Avatar
I wish I saw that yesterday, did the power steering pump on my best friend's wife's car. We got it pretty clean though.
Old 02-03-2019, 06:47 PM
Don't know if I'll try this with my truck but I might. The question that comes to mind is would cycling the ignition on & off several times affect my glow plugs on my old 7.3L in some negative way?
Marv Evans
'69 911E
Old 02-03-2019, 08:13 PM
Team California
speeder's Avatar
No.
Denis
Old 02-03-2019, 08:15 PM
ThanX !
Marv Evans
'69 911E
Old 02-03-2019, 09:22 PM
Arizona_928's Avatar
I was waiting for him to put atf back in, and bam power steering fluid from Checkers!
Hey it's dangerous to work on a car that's running!
dolor et pavor
Copyright
Old 02-03-2019, 10:08 PM
I have seen the smart boxes go bad on the hmmwv's and they'll default glow plugs on and burn them out. They're the swelling type too! 7.3 is fine. There's a Canadian on youtube that has a idi 7.3 with no working glow plugs, and feeds it "Bill Cosby in a can" ether to get it started.
dolor et pavor
Copyright
Old 02-03-2019, 10:11 PM
HarryD's Avatar
Interesting. I have always did this by:
1) removing the fluid from the reservoir with a turkey baster,
2) refill it,
3) run the car,
4) turn the wheel left and right,
5) remove the fluid,
6) if looking fresh, refill and stop.
7) If still dirty, go back to step one.
I tend to use one large bottle to be sure. No worries about messing up hoses.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-03-2019, 10:39 PM
2) refill it,
3) run the car,
5) remove the fluid, sohbet
Old 02-04-2019, 03:12 PM
