how to remove emblem adhesive from truck ?
Today I was fed up with looking at the Duramax and GMC emblems on the passenger door so I pulled them off . The drivers side were not on there when I bought the truck used probably dent/crash repair related . Anyway I now have black adhesive residue left over from when they were installed in 2001 :eek: I have peeled off and scraped with a wooden paint stick the majority of the thick stuff . Searched online and many suggest spray with WD40 or similar over a few days then hit with heat gun and the rest will come off .
Have any of you had success with this method ? Or any other tips ? I have a heat gun that I would only use on low setting . Today I hit the area with WD40 and will keep hitting it as weather permits as it's supposed to rain here for the next 4 - 5 days or more ! :mad: Many years ago I bought an eraser pad from NAPA that you chucked into a drill . It was beige in color and kind of like a giant pencil eraser . I used it to remove tape pin stripes and it did a great job . I think the friction created enough heat to somewhat melt the tape/adhesive . Any tips or suggestions are appreciated . I'm getting ready to get some graphics on the truck but have to get this area cleaned up first . SmileWavy |
I would stay away from anything potentially abrasive.
Chemicals. You have to find the right stuff. Why not just an adhesive remover in a spray can? |
Goo gone...works good for sticker adhesive..
Hairdryer will work.. heat the adhesive and use your finger to roll it |
I've used goo gone for the last bit of stuff for debadging my M3s.
Sounds like some heat and finger action then some goo gone for final clean up . Thanks
Either goo gone, or a product called sticker shock
WD40 here. Followed by a little rubbing compound. Goo Gone did not work for me.
Try white vinegar, although if left on too long it can cause bare metal to corrode.
Mike |
Peanut butter - seriously
goo gone or peanut butter work for me
3M adhesive and label remover.
Lighter fluid or BBQ starting fluid works great.
http://www.amazon.com/exec/obidos/redirect?link_code=ur2&camp=1789&tag=wwwpelicanpar-20&creative=9325&path=https://www.amazon.com/Stripe-Wheel-07498-Diameter-Mandrel/dp/B00063VT0G/ref=asc_df_B00063VT0G/?tag=hyprod-20&linkCode=df0&hvadid=309807921328&hvpos=1o1&hvne tw=g&hvrand=8029341933215608155&hvpone=&hvptwo=&hv qmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031539& hvtargid=pla-451421021261&psc=1
This. Works like magic. I've used several over the years, never burned or disfigured any paint. |
I also vote for goo gone. Put it on a few times to let it really soak in and soften the adhesive gunk. Then if you do need to use a scraper, use a plastic that is softer than the paintwork. I use a kitchen fish slice that's intended for non stick pans.
+1 for colingreene
The 3M or Carborundum vinyl graphics wheels chucked up in a drill will safely remove the remnants. Work great on the inner barrels of wheels to get rid of the old foam/adhesive from wheel weights. After you remove the adhesive just follow up with some mild polish or cleaner wax. http://forums.pelicanparts.com/uploa...1550119096.jpg |
| All times are GMT -8. The time now is 08:40 PM. |
