rfuerst911sc's Avatar
how to remove emblem adhesive from truck ?
Today I was fed up with looking at the Duramax and GMC emblems on the passenger door so I pulled them off . The drivers side were not on there when I bought the truck used probably dent/crash repair related . Anyway I now have black adhesive residue left over from when they were installed in 2001 I have peeled off and scraped with a wooden paint stick the majority of the thick stuff . Searched online and many suggest spray with WD40 or similar over a few days then hit with heat gun and the rest will come off .
Have any of you had success with this method ? Or any other tips ? I have a heat gun that I would only use on low setting . Today I hit the area with WD40 and will keep hitting it as weather permits as it's supposed to rain here for the next 4 - 5 days or more ! Many years ago I bought an eraser pad from NAPA that you chucked into a drill . It was beige in color and kind of like a giant pencil eraser . I used it to remove tape pin stripes and it did a great job . I think the friction created enough heat to somewhat melt the tape/adhesive . Any tips or suggestions are appreciated . I'm getting ready to get some graphics on the truck but have to get this area cleaned up first .
Old 02-13-2019, 03:36 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I would stay away from anything potentially abrasive.
Chemicals. You have to find the right stuff.
Why not just an adhesive remover in a spray can?
1981 911SC Targa
Old 02-13-2019, 03:45 PM
Goo gone...works good for sticker adhesive..
Hairdryer will work.. heat the adhesive and use your finger to roll it
Old 02-13-2019, 03:49 PM
I've used goo gone for the last bit of stuff for debadging my M3s.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 02-13-2019, 03:54 PM
Sounds like some heat and finger action then some goo gone for final clean up . Thanks
Old 02-13-2019, 03:59 PM
unindicted co-conspirator
looneybin's Avatar
Either goo gone, or a product called sticker shock
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 02-13-2019, 04:00 PM
Bob Kontak's Avatar
Don't suffer. Use the Goo Gone right away. It will not mess with your paint.
1981 911SC Targa
Old 02-13-2019, 04:01 PM
WD40 here. Followed by a little rubbing compound. Goo Gone did not work for me.
msk1986911's Avatar
Try white vinegar, although if left on too long it can cause bare metal to corrode.
Mike
Old 02-13-2019, 04:40 PM
It'll be legen-waitforit
stealthn's Avatar
Peanut butter - seriously
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Control Group
Tobra's Avatar
goo gone or peanut butter work for me
Old 02-13-2019, 05:16 PM
3M adhesive and label remover.
Old 02-13-2019, 05:19 PM
Registered Abuser
MT930's Avatar
3m adhesive and label remover.
+ 1
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 02-13-2019, 05:24 PM
Lighter fluid or BBQ starting fluid works great.
Old 02-13-2019, 06:09 PM
Bill Douglas's Avatar
I also vote for goo gone. Put it on a few times to let it really soak in and soften the adhesive gunk. Then if you do need to use a scraper, use a plastic that is softer than the paintwork. I use a kitchen fish slice that's intended for non stick pans.
Old 02-13-2019, 08:23 PM
Cooper911SC's Avatar
+1 for colingreene
The 3M or Carborundum vinyl graphics wheels chucked up in a drill will safely remove the remnants.
Work great on the inner barrels of wheels to get rid of the old foam/adhesive from wheel weights.
After you remove the adhesive just follow up with some mild polish or cleaner wax.
Old 02-13-2019, 08:38 PM
That is what I purchased years ago at NAPA and it worked well . I'm going to try the chemical route first if that fails the 3M eraser will be next . Fortunately it's not a large area to take care of .
Old 02-14-2019, 03:14 AM
Brew Master
cabmandone's Avatar
I used this stuff. It works "okay" imo. Anymore I just use a heat gun and some goo gone to clean up after.
Nick
Old 02-14-2019, 06:27 AM
