Well, I assume that you will be painting it, as any steel that is left outside needs to be painted. If you paint the part that goes in the concrete, it will be fine. I would suggest that the concrete that you pour be an air-entrained mix. That will need to come from a readymix company, it’s not something you’re going to mix yourself out of a bag from Home Depot in a wheelbarrow. Slope the top surfaces of any exposed concrete for drainage and caulk around the steel concrete interface.
I'm looking forward to doing the restoration of the piece itself. It will neat to see it all clean and shiny again. It's one of those things that makes no sense financially but even running numbers still makes me smile. |
If you plan to remove it later, you should consider that in your design. With regards to the center post, take a look at how flagpoles are anchored to the ground. With respect to the fins, consider welding a flat base plate on the bottom of each fin that can be bolted to the concrete that you pour. When you move, that would allow you to unbolt everything, remove the center pole and off you go.
Thanks again for the suggestions! |
I watched them replace the street lights in our 'hood doing something similar. They had pre-drilled plywood forms that they mounted the J bolts to when they poured each of the footings for the new poles. They just supported the plywood on top of the forms so the J bolts stuck out the desired amount. Worked out well as the poles just slipped right over the J bolts without much trouble when they set the poles.
Scott '78 SC mit Sportomatic - Sold |
We call those anchor bolt templates, in the business. In my world, they are usually made from steel plate, but plywood also works for smaller projects like this. The idea is to place all of the templates in place prior to the concrete pour, so that you can verify the alignment, spacing and elevation/projection of the bolts.
It's a good idea for this project especially since he wants to be able to move it later.
The J bolts used on the light poles were @18-24" long if I remember correctly. I didn't actually measure them though.
Any progress on the rocket?
82 SC , 72 914 |
By far my favorite playground equipment when I was a kid.
I haven't driven by lately but google maps still shows this one near my house: ![]() As I recall, they do sway a bit so I'd say the fins mounted in concrete is a must.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Not sure if someone mentioned an epoxy based paint where it is stuck in concrete. I would do that.
Still Doin Time
I'll solve your problem by taking it off your hands, putting it in my backyard
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
You do not have permissi
Someone(baz I think) mentioned using Ospho as a anti-rust prep before painting.
A good choice after looking at vids. Once that structure has been cut at near ground level you have all the choices in the world to attach it to base. -Add reinforcements. -Add chamfers and corner brackets. -But treat any below ground metal first.
Meanwhile other things are still happening. Last edited by john70t; 10-14-2020 at 12:37 PM.. |
The only having 1 day to plan & remove severely limited options. Being 1000 miles away I didn't even have time to get there and had to leave it up to a few friends to somehow keep it from going to the scrap metal yard. In a perfect world I would have arranged to have it lifted whole and laid on a trailer to move here. Instead I could only arrange 3 friends with a toolbox, a sawzall and a Uhaul truck.
