Fleabit peanut monkey
Bob Kontak's Avatar
Subaru Missfire
Sister's 2005 Outback Impreza Sport wagon. Running rough. Big missfire(s).
Basic 2.5L NA engine.
Pull plugs. Every one is bathed in oil past where the boot plugs on in the tube.
Valve cover gaskets/seals gone.
You think this might be a problem?
1981 911SC Targa
Old 03-15-2019, 03:38 PM
I'd guess coil pack...plug doesn't look fouled. Just a guess.--Dave
Old 03-15-2019, 03:45 PM
What?!?!
DonDavis's Avatar
Yup, I think you nailed it. Replace the plugs, plug wires and coil pack.
Replace the valve cover gaskets with factory new ones. Take your time with the gaskets. They are directional, closely inspect the old ones for tiny lines, compare to your new factory gaskets. And please properly torque the cover bolts.
I bet it’ll run great after that.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 03-15-2019, 03:50 PM
Lots of snow Porsche away
On the 2.5 na for sure it is common to have oil bleed down the plugs, the valve cover gaskets suck.
All of the above absolutely in the nail.
Old 03-15-2019, 04:33 PM
Bland
unclebilly's Avatar
That is the issue.
Old 03-15-2019, 04:53 PM
Bob Kontak's Avatar
Originally Posted by unclebilly View Post
That is the issue.
Yepper! Told my beer drinking pal "I am going to post this because many of these guys know these cars better than me."
I have replaced the four cluster coil unit, plugs but not wires.
Should have as the rubber boots, similar to the old 911's but not a hard tube were extremely floppy. Tired and played. Car was way smoother but under acceleration, some missfire again.
Remediation is short term without valve cover gasket fix.
1981 911SC Targa
Old 03-15-2019, 06:10 PM
Oracle's Avatar
All subaru's engine sound like they misfire... (at least to me)
and the heads all crap out, they are made to make you spend sooner or later and question yourself why did you get that car in the first place..
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 03-15-2019, 08:08 PM
SCadaddle's Avatar
Agree 100% with this, and that's from currently owning a 2005 Legacy with the 2.5 2 cam engine and a pair of older Legacy's with the 2.5 4 cam engines.
On the 2 cam 2.5 engines the "spark plug boot" between the spark plug tube and the valve cover over time become hard as a rock and fail to seal the spark plug tube from the oil in the valve train. It's a pretty easy job and use all new grommet seals around the bolts (5 per side more than likely on that engine) a pair of new spark plug boot seals and a new valve cover seal. Just have to be real careful putting the valve cover on, try going straight on with it so you don't fold or misalign the spark plug boot seals by moving the cover up and down when putting it on. Great time to check the valve adjustment while you are there.
Old 03-16-2019, 01:52 AM
SCadaddle's Avatar
Spark plug tube seal.
Original 89k mile 14 year old spark plug tube seals, one that was misaligned by the factory from the beginning. Both hard as a rock.
Old 03-16-2019, 02:08 AM
SCadaddle's Avatar
Inside of valve cover. Note where the spark plug tube seals seat. That's why you don't want any up-down movement when putting it on or you will deform the seal.
Old 03-16-2019, 02:17 AM
Brew Master
cabmandone's Avatar
The Impreza I bought for my daughter had a light show going on at the coil pack when it was dark out. Car was running like crap. Replaced the wires and did plugs while I was at it and it ran like a top. Yeah.. those valve cover gaskets suck and others have pointed out the plug seal. And for all the gripes... I still miss my 95 Legacy wagon (ATV with air)
Nick
Old 03-16-2019, 03:24 AM
What?!?!
DonDavis's Avatar
Such great information!
My '96 Legacy Outback 2.2 SOHC wagon has 312,000 miles and runs like a top. I stumbled into owning this beast for $600, did a BUNCH of regular maintenance and upkeep and it's the bee's knees.
I'm in it for less than 2k. Such a cool car.
Old 03-16-2019, 09:14 AM
Bob Kontak's Avatar
Do you have lift the engine at all to perform this maintenance? Meaning up off the motor mounts a few inches?
1981 911SC Targa
Old 03-18-2019, 11:40 AM
fastfredracing's Avatar
From what I remember , one of the rear lower bolts is a sob, and lifting the motor a little bit makes it much easier . I just cannot remember if this was a 4 cyl, or 6 cyl car . I do remember spending a lot of time turning just one valve cover bolt .
Good luck Bob !
No left turn un stoned
Old 03-18-2019, 11:46 AM
Bob Kontak's Avatar
Originally Posted by fastfredracing View Post
I just cannot remember if this was a 4 cyl, or 6 cyl car . !
4 cyl 2.5. Thanks for the info. I did see one vid on a newer version where bunches of auxiliary stuff had to be removed for access but it still boiled sown to one or two stinker bolts.
1981 911SC Targa
Old 03-18-2019, 11:50 AM
Bob Kontak's Avatar
Replaced wires Saturday. Smooth running engine now but she probably has three days until the plugs drown again.
1981 911SC Targa
Old 03-18-2019, 11:53 AM
VincentVega's Avatar
Good luck Bob !
x2 I dont remember the year, maybe late 90's? Doing valve covers on one almost had me giving up my tools.
Old 03-18-2019, 12:03 PM
Brew Master
cabmandone's Avatar
I did valve covers on a 2.2 and it wasn't a terrible experience. And to be honest, pulling a 2.2 or 2.5 is about as easy if not slightly easier than dropping the 3.2 out of my 911.
Did a little surfing. The link below covers Timing belt and valve cover replacement. Ignore the tb info and just grab the valve cover info.
https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/26199-2001-timing-belt-water-pump-valve-cover-gasket-set.html
Nick
Old 03-18-2019, 02:16 PM
I changed my impreza engine, pulling it for the first time, alone, it was on the floor in less than two hours.
76 911S
86 GMC K1500
78 XS750 cafe racer to be
79 XS750 because one is just not enough
Old 03-18-2019, 02:21 PM
Bob Kontak's Avatar
Thanks for the info, guys.
1981 911SC Targa
Old 03-18-2019, 02:26 PM
