POR15 removal
Has any one in the Pelican brain trust removed POR15 from metal? If so what did you use/do?
Reiver
c4
De Oppresso Liber Strength and Honor 5th Legion |
mechanically, wire brush grinder takes it off easily. Chemically, does aircraft stripper work? If not, powder coating stripper would definitely work.
Tru6 Restoration & Design |
Years ago I use a paint on stripper (citrus I think), that did a really good job.
Marv Evans '69 911E |
Read a few threads on other forums with mixed info. Seems aircraft stripper may work. So I'll give it a try.
Painted my oil tank with the stuff, I don't like. So need to remove it. |
Robert ----------------------------------------- "A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe) |
Is painting over the POR 15 an option for you ? Seems it would make a good " primer " for a top coat and help protect the tank from external rust . And this would save you the time to strip it off .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
This is an excellent suggestion. I think there's something in the POR literature that refers to using it as a primer. Been a while since I read it.
I will look into painting over it. I was under the impression once cured it was very diffiecult to get anything to stick so didn't even consider as an option. Extremely hard so hard to sand to get any tooth. But if I can far less work and an extra layer of protection. I will try before I use the aircraft stripper.
rfuerst911sc, how is the boat? Haven't seen ay posts lately. |
You can scuff it with sandpaper and paint over it. Good option.
Fleabit peanut monkey
just from memory.
1981 911SC Targa |
I heard brushing rustoleum satin black over POR15 as soon as it starts going off (drying)
What is the drying time for POR15 say 70 degrees indoor for floor pans ? Is this method good ? Satin Black ? |
So I read the can. Clear states it can be top coated. After cure sand to 320. It gums up 320 pretty quickly, so I started at 120 and will work up. It's some hard *****. It's going to take a while.
Good call rfuerst911sc. My mom always used to get so mad at me because I would never read the directions. It's amazing what you learn if you read the directions. |
