How much does cedar privacy fencing shrink?
Obviously freshly cut several weeks ago, kept in my garage, then on my back deck a week or so gettin' humid
. So I butted them together, with screws, in a couple of days...1/8" gap...make it stop . Should I lay these remaining planks out & bake on my deck....before installing....or not, due to warping, etc. I was picky as I went through the stock....and kept them all "true".... if that's all they're gonna shrink....I'm good....don't want huge gaps though....I've never used cedar before.....same shrinkage as pine crap or whatever the typical stuff is? Last edited by KFC911; 04-28-2019 at 02:00 PM.. |
Platinum Member
If you shrink them (let them dry) then screw them tight, no gap, you will not be happy when the moisture content goes back up and they buckle.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
^^^^ Yep....really depends upon how long it's cured a bit I suppose. I was shocked at the gap after just a couple of days...just getting started...so I asked. 1/8 (as is) will be fine....don't want larger....walkin' the line
. One fence I did years ago...I spaced them with a nail and the gaps ended up huge.....arg .Meebe I should hire a guy...that ain't so picky....but I'm too picky....it's a curse .
Platinum Member
![]() Stretches 600% for a crackproof finish.....Seals joints up to 3 in.
If you want to get all scientific about it, you can measure the moisture content as it sits and estimate the moisture content it will eventually achieve in your particular climate and calculate the shrinkage. You won’t have a meter to measure the moisture, but you could buy one, if you were so inclined. Most likely you could install them fairly snug now, as I suspect that the moisture content will never be higher than it is now. In any event an 8th inch or 3/16 inch gap is nothing, when you’re viewing the fence from 50 feet away.
![]() JR....I have "issues" ...the little section I put up (gate, etc.) look great w/ 1/8" gaps....I'm standing 12" away...need to redo the gate a bit....then proceed. So I axed....Thanks all...especially the caulk tip! |
You don’t caulk a fence, but you probably know that...
As long as the gaps are uniform, you shouldn’t give two craps about what the number is. |
I'm going with caulk....
I'm in the process of taking them off the gate (need to tweek it a bit anyways, wouldn't otherwise)....looks great. I can close those 1/8" a bit...mebbe....I think....just askn'? These are really not long runs 25' & mebbe half that on the other side....blocking back from the street/lights/cars etc. out front....paradise out back...acres of it....so dawgy likes ![]() Yeah....I know....but just can't help myself...thanks! |
Unregistered
just what exactly are you doing behind that fence that requires so much privacy mister?
Never mind, don't wanna know. |
Nuthin'....cars lights bugged me leanin' against the back rail facing forward last nght. Didn't sleep at all last night...like when yer switch/outlet cover plate screws don't all align straight up & down. Some of y'all might understand....it's a sickness I tell ya
![]() I'm gonna sleep goooood tonight
Unregistered
Platinum Member
![]() I was kidding about the caulk, but that's pretty good stuff. Here's a few more to drive you nuts. ![]()
You do not have permissi
Dust? You have dust in your house?
omg..... |
2% per 10 degrees over 80F per month...Decreases by .0008% week after that......Rough estimate....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Banned but not out, yet..
My cedar fence has been up for two years and each picket has shrunk about 1/4” (1/8” per side) which means a quarter inch gap between boards. Just the nature of wood.
An air cooled refrigerator. ‘Mein Teil’ |
^^^^ Well since Sammy had me up filing screws....I decided to go pound on my neighbor's front door at 1am....with my other neighbor's alpha GSD at my side....the one's that called the popo Sammy
.I figured if it gaps to 1/8" in less than 2 days baking...those I repositioned butted together today will end that way. I'll "cure" the rest unstacked for a day or so.... Thanks guys! I've got screws to file....but methinks the neighbor's might need another alpha instead of me....I LOVE GSDs....and lab pups.....to show them the way to get along with the 'hood...I think we made progress.... woof! Last edited by KFC911; 04-29-2019 at 10:39 PM.. |
Can you place a board over each seam ? I think it's called shadow box ? No light will be getting through that .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
