VW TDI 6 speed manual
Hi Folks,
I'm posting this here because of the volume of eyeballs here is greater than the VW groups. I have a 2011 VW TDI Sportswagon with the 6 speed manual transmission. I finally changed the tranny oil at 200k miles. It was a little dark and burnt but still felt like gear oil should feel. I replaced it with Redline MTL. The car has 250k miles now and the transmission has a hard time going into 1st. When I come to a stop light, I put the car into neutral and wait for the green light. When the light turns green the tranny won't go directly into 1st. I have to shift down (pull the stick down) into 2nd and then push up into 1st. This is more of an annoyance than anything else. I'm considering changing the oil now to a different fluid. VW calls out their own spec gear oil for this transmission and its pricey. I forget how much but it was significant; maybe $60 a liter/quart Some people use a GM spec oil for their transfer cases, Pennzoil Synchromesh. This oil is available at the usual places like Autozone for around $7/quart Anyone here can shine a light on my problem? thanks |
Banned
I think that it's extremely important to use the correct factory oil in that transmission, not some off-brand that may or may not meet the specs for the factory oil. I remember that when I had to rebuild the 5-speed in my 2006 Jetta TDI, (really the same transmission), I bought the oil from the dealer and it was a very specific specification. I could have gotten it aftermarket but it was actually cheaper at dealer. Go figure.
The reason that manual trans oil is so important wrt using the right stuff has to do w the synchros the factory put in and what is best for them as well as differential clutches in that trans. Have you ever changed the clutch? The cover or pressure plate might be getting tired. |
Still have the same clutch. Most of my driving as been in Los Angeles on the freeway.
I may just bite the bullet and get the oil VW calls out. The dealer usually doesn't have this oil in stock so I'll have to order 2 quarts and make two trips. Or just go to Autozone and get the Pennzoil Synchromesh. 2 quarts for $16 and see how it works. |
I use febi oil. In my cjaa I replaced the manual fluid at 100k mi. 200k is waaaay too long on that transmission. The fact that you have to use the syncro's from second to get into first tell you that the 1st gear syncros are done. prolly not going to be an issue unless you down shift into first without stopping, then you'll prolly just get a crunch shift...
dolor et pavor Copyright |
I would definitely change the fluid back to the recommended VW fluid.
But it sounds to me like a deeper issue. I would look for a used gearbox as plan B. New fluid rarely fixes a manual transmission problem, but it's worth a shot. Lots of 915 gearboxes had that same issue, but a newer VW 6 speed should go right into first gear easily.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 05-02-2019 at 07:25 AM.. |
Don't use 2nd to stop the input shaft, that's probably going to be your next synchro to go bad based on use. Maybe use 4th. Ideally spread it around a few gears.
Banned
Definitely use the correct oil for that transmission. For a component that major that only has its oil changed every 100k miles, you’d be a fool to use the wrong oil because of the convenience of going to Autozone.
Actually, Autozone should be able to get the correct oil if the employee has the skills to look it up. I know a place in Glendale that could have it for you later today, where are you located? |
What?!?!
![]() Why do this? Put it in the necessary gear before the light changes. Wrt to the sync issue, I'd flush trans and go with factory recommended oil before any other part replacement. My Subie OBW shifted like crud when I bought it, flushed in 2 changes of proper oil over 500 miles and it shifts very well now. I think my issue was just old crappy oil. But that's where I'd start.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross Last edited by DonDavis; 05-02-2019 at 11:44 AM.. |
As a person who has lived in lots of countries, I do not understand why traffic lights are obscured from perpendicular traffic in the USA. When you are sitting at a red light you can't see when the other light is amber.
Being able to see the status of the lights for the perpendicular traffic allows you to be ready to move when the light changes. Some countries even have amber before green, to warn you.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Redline makes good oil but id probably use the factory fluid. 50k seems on the higher end of the schedule, no? I do every 30k.
Doesn’t that put excess wear on the throwout bearing? It takes me a few seconds to put the car into gear and take off on a light, no big deal. |
What's more expensive, $120 of the correct fluid or a $500+ used transmission and $1K in labor to put it in?
Tru6 Restoration & Design |
Banned
It's nowhere near $120 for the correct oil for that transmission.
He said it's $60 a quart and needs 2.
Banned
I got oil from the dealer today
it wasn't nearly as much as I remembered so I got 2 liters and I'll change the tranny and crankcase oil tomorrow. $14/liter it also looks like a different part number so maybe VW changed something |
Banned
G 052 171 A2 is the correct part#.
Banned
Hmmm, they might have given you the wrong stuff. The 171 is a good number as of today from my VW dealer and my aftermarket place. Straight from VW parts counter, today.
they asked for my VIN so I hope they gave me the right stuff
it may just be a non synthetic gear oil its really thin by just shaking the bottle
What?!?!
I just think it's a smoother operation to wait with it in gear.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
