-   -   Spacer question (http://forums.pelicanparts.com/off-topic-discussions/1029737-spacer-question.html)
DWBOX2000 05-16-2019 05:00 PM
Spacer question
Son and I are making some changes to his miata. He wanted spacers which leads to my question. Front went on okay. The back spacer does not fit because of a non metallic ring (magnet doesn't stick to at least) that is on the hub that the spacer hole is too small to fit around. Is it a spacer issue or do I remove the ring? The spacers have the bolts attached. See picture. Any advice sppreciated. Thankshttp://forums.pelicanparts.com/uploa...1558051120.jpg
http://forums.pelicanparts.com/uploa...1558051207.jpg
sc_rufctr 05-16-2019 05:07 PM
Could it be a ring from the wheels you removed? (Some multi-fit wheels have inserts)
Is the ring plastic or alloy?
DWBOX2000 05-16-2019 05:18 PM
It seems like a metal, not plastic. What it is made of I don't know. Thanks for responding.
cabmandone 05-16-2019 06:47 PM
Wouldn't that lip indicate the wheels are hub centric? If so you might check the spacer manufacturer to make sure the spacers are hub centric.
DWBOX2000 05-16-2019 06:53 PM
They said they were hub centric.
Tobra 05-16-2019 08:32 PM
They sent you the wrong spacers would be my guess, are all four the same?
Yes, Miata is hub centric. It may be that the hub centering rings got stuck on the hub
cabmandone 05-17-2019 05:14 AM
If you have a digital caliper, check the ID of the spacer and the ID of the wheel. That should tell you pretty quick where the problem is.
DWBOX2000 05-17-2019 07:43 AM
If there is a hub centering ring, do they just pop off with a little prying or is it typically more involved. I've lost my sense of adventure regarding just pulling things apart without asking. I've cost myself many the $ with my poor skills.
Thanks everyone.
DanielDudley 05-17-2019 01:10 PM
https://www.miata.net/
masraum 05-17-2019 06:29 PM
I think the little ring should be removed, IIRC, from my days with a miata.
DWBOX2000 05-17-2019 08:03 PM
It popped off. I put on spacer, put ring on rim and put rim on car. Seems good.
Thanks everyone.
