The '06 4s I'm rebuilding looks like yours, customer's doing the full LN treatment, plus just about everything else on the greasy side.
http://forums.pelicanparts.com/uploa...1561411267.jpg Bore scoring is another issue however..... |
What is causing the bore scoring? Bad rings, poor cylinder material?
Bummer Rob, it's a nice looking car. And it sounds like you were having good fun with it. All the best in getting it fixed well. Cheers Richard |
I should have qualified my statement; you cannot replace the IMS w/o completely tearing down the engine. So you could do it once on this one. Not sure what you would do when that wears out in 40k miles, (or whatever the service life is).
This is a sad example of how these engines are completely unsuited for track use. :( |
Speeder is wrong.
Go do a search on Rennlist, there are a number of rebuilders out there that can do a proper rebuild up to and including full track use. I will concede its not cheap. |
Thanks!
Porsche IMS Bearing Tool Kit - Intermediate Shaft Bearing Repair Tool Kit 996, 997, Boxster, Cayman — European Parts Solution There's a video (can't get it to embed here) on that page that shows the issue and the product in use. http://forums.pelicanparts.com/uploa...1561427273.JPG |
bore scoring can be re-mediated with sleeves.
And prevented with improved cooling Make sure you have the 70 C thermostat so you get cooler coolant to your engine. |
I assume you would want to do a rebuild with the LN Nickies? This way they are nikacil plated like the good ole aircooled engines! :D
Wheeler dealer make it looks easy.
<iframe width="560" height="315" src="https://www.youtube.com/embed/S8Pu6BMgqAs" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
| All times are GMT -8. The time now is 08:42 PM. |
