Any Recommendations for getting rid of moss on roof?
My roof is fairly new at 7 years old with 50yr asphalt shingles. It's starting to get some moss on the shingles. Anyone have a recommendation for getting rid of this? I don't want to spray something that runs off and kills my plants on the ground. I also thought about using a pressure washer but don't want to damage the shingles.
Photo of Shingles - before moss build up (to show type of shingle)
Old 07-10-2019, 10:28 AM
Member
i used HD deck cleaner with the pressure washer on medium pressure.
This worked well, then a roofer told me a secret.........
install a strip of copper sheathing under the top cap, it should show about 3 inches.
The miniscule copper element in the runoff will prevent moss and lichens from growing.
Works like magic.........no more washing the roof!
Paul
91 964 C2 Targa sold (shipped back to the fatherland)
09 Cayman PDK 17 Titan
55 Sunbeam S7 Deluxe
70 Triumph Bonneville
Old 07-10-2019, 10:49 AM
Wow, moss on a roof in Fresno?
Never would have thought you'd get that kind of problem there with as hot as it gets.
This must be on a north facing roof which is shaded almost constantly by trees, if I was guessing.
Sorry I don't have any suggestions.
Scott
'78 SC mit Sportomatic - Sold
I bet that copper trick works slick, Paul. Just like driving a copper nail into a tree if you want to kill it.
Scott
Old 07-10-2019, 10:50 AM
AutoBahned
RWebb's Avatar
use a spray with iron sulphate etc. in it - should only kill the moss, which is very sensitive to ferrous compounds rel. to vascular plants
that will kill it; not remove it - pressure washer will do that but abrade the shingles somewhat
a strip of Cu along the roof line works great long term ($$$)
maybe trim some trees to get more sun in those areas - moss will grow if the environment favors... moss
Old 07-10-2019, 11:25 AM
pwd72s's Avatar
This product has worked for me for decades. Beware of copper, can corrode galvanized or aluminum gutters. This a zinc compound...but the runoff can damage lawn grass. Never had any shrub damage, but won't say it couldn't happen.
https://www.corrys.com/all-products/moss-b-ware
Old 07-10-2019, 11:30 AM
LWJ LWJ is online now
Here in the PNW, we get moss. Lots of it.
Iron and copper are typical remedies. You can also use laundry detergent sprinkled on the roof. This may be problematic with the down stream water shed. Not certain of your situation.
It works very well. It will kill the moss but then you may wish to blow / wash the moss off.
Good luck from moss country to moss country!
Old 07-10-2019, 11:34 AM
AutoBahned
RWebb's Avatar
best thing would be to start a moss rant thread in PARF
start with some name calling about them being "primitive" plants and how they suck compared to angiosperms
Old 07-10-2019, 11:38 AM
Non Compos Mentis
It works very well. !
While very effective, and much less expensive than products marketed as moss killer, laundry detergent will degrade the asphalt in the shingles. Over time, the granules will begin to lose adhesion and end up in the gutter.
Old 07-10-2019, 11:51 AM
nice guy
Old 07-10-2019, 11:53 AM
The Stones ARE on tour...have 'em come roll around on yer roof .
Old 07-10-2019, 12:03 PM
nice guy
no roof
tent
Old 07-10-2019, 12:07 PM
Evil Genius
Rusty Heap's Avatar
this is my go to product.
shake it heavy dusting up at your ridge crest.
right before a light drizzle.
zero issues.
zinc flashing up top works too.
Life is a big ocean to swim in.
Wag more, bark less.
Old 07-10-2019, 12:08 PM
wdfifteen's Avatar
Spray and Walk Away. I’ve used it on a couple of projects. Apply with a pump sprayer, so little to no run off. It may take weeks for the moss to go away, but it doesn’t come back.
https://www.homedepot.com/p/30-Seconds-1-Gal-Cleaner-Spray-and-Walk-Away-100506799/202897313?MERCH=REC-_-PIPHorizontal2_rr-_-206409694-_-202897313-_-N
Old 07-10-2019, 12:16 PM
Wet it and Forget it is a good product and easy to use.
Old 07-10-2019, 03:31 PM
Originally Posted by Clint Lando View Post
LOL..I missed that right before I posted before....yeah you right!
Old 07-10-2019, 04:07 PM
Moss is a moisture issue similar to mold. Cut down all your trees so you get more sun light, change the PH buy a commercial moss control agent which changes the PH.
Old 07-10-2019, 04:14 PM
AutoBahned
RWebb's Avatar
also... napalm - kill it good
Old 07-10-2019, 04:16 PM
I live in a very heavily tree'd area. You can slightly tell in my photo above.
The moss on my roof appears mostly dead as we are now having summer heat (100+degrees). So now, it's more like a crust at the edge of the shingles but it will become slimy once winter shows up. I also have a lot of brick walkways and patio which always get moss in the winter. I've tried roundup but the moss comes right back.
Old 07-10-2019, 04:24 PM
HobieMarty's Avatar
Bleach mixed with a little dawn dish soap, spray with low pressure. The bleach will kill the moss, the dish detergent gives the bleach a clinginess so that it won’t run off quickly. Rinse with low pressure. There are videos on YouTube explaining how to do this.
Wonka
Old 07-11-2019, 12:03 AM
