Yesir in no way am I advocating a slightly above median earner buying a new C8, but we all know they will in droves
Ill get mine preowned in 5 years. Corvettes are the best cars to buy used. Alot of owners baby them and they depreciate relatively quickly |
Help me understand how this car will perform THAT much better than the current Corvette that has perfect 50/50 weight distribution and crazy hp? I just don't see how making it mid-engine will make it all of sudden destroy the current performance of the Grand Sport or Zo6 with the same or less hp. The 8spd auto prob makes the most improvement in performance (moreso than the mid-engine design).
C7 GS 0-60 3.6
C8 45+HP and DCT 0-60 sub 3 Compare a Golr R 6spd and DCT 0-60 its huge. |
I think where the mid engine will really start to shine is in the higher hp variants. The engine starts to get much heavier with big SC and inter cooler. I think a lot of it is to appease the 0-60 magazine types. I think the lower polar moment and the noise coming from behind you will give the supercar experience even if it doesnt equate to huge losses in lap times.
You are right current vettes in the right trim are already pretty damn fast. I think in the base model it will be an incremental improvement but allows headroom for the really fast models I have some speculation they were somewhat limited by cooling in the front engine models as well. Now they have more room up front for clever radiator packaging and they have huge side scoops for oilcoolers, intercoolers, etc. |
According to the engineers they were at the limit for acceleration and traction with the front engine car.
I suspect that the front-mid with more dumbell effect (front engine, rear transaxle) would actually help 99.9% of drivers drive more quickly by slowing down rotation a tad (like a 944) versus more central rear-mid with engine and trans in a single lump fairly center with quicker rotation that most folks can't handle. I think I've read an article where Derek Bell said the 944 was actually faster than a similar hp/weight ratio 911 in the hands of almost anyone because the 944 was more stable and easier to push to and over it's limits. |
Pretty F'in awesome engine.
they put some time into this! headers are gorgeous. https://www.hagerty.com/articles-videos/articles/2019/07/22/how-the-mid-engine-corvette-lt2-v-8-improves-on-the-lt1?utm_source=SFMC&utm_medium=email&utm_content=D aily_News_Wednesday_July_24 |
There's a lot to like about this car, but man, it looks like an elephant sat on the trunk of a Camaro back there.
http://forums.pelicanparts.com/uploa...1563577262.jpg |
Acceleration gets better benefit in the rear weight biased car. There is more vertical pressure on the rear contact patch relative to the car's mass. When you flip to the braking side of things, a balanced or front weighted car has to have significantly greater front wheel brake bias as you have weight shift under braking. Rear weight biased cars do not need as much forwards brake bias. Beyond these three points, there other factors that are far more complex that my understanding is not developed enough to explain. |
Jason from engineering explained, shows the benefits of rear mid from a traction limited perspective on the C8
https://www.youtube.com/watch?v=E_SH4c-oLUQ From the 0-60 perspective it makes complete sense. I am more curious how it will compare on a roadcourse to say a c6zo6 with the same tires. Power and weight are similar. I am sure it will be a bit faster with a decade or so of advancement but I wonder to what extent. |
The rearward weight bias also helps in hard braking.
| All times are GMT -8. The time now is 07:52 AM. |
