Good luck with your soaking tonight , please update with the results .
I’ve done this more than once.
Get an electric bug zapper Put is near. Closer is best. Let it do its thing. It should really jump for a while. After the occupants are 80-90% gone, hit it with a hose / shovel. Done. |
Hair spray and a lighter...
I had a huge hornets nest like that on my house. It sprayed it several times from about 10 feet away over several days. Each time it killed some until eventually all were gone. You should do it after dark when they are on the nest to do the most damage....and in the daytime, they will chase you down as there will be many out flying around that will come back to you violating the next. Hornets boil out of a big nest by the hundreds or even thousands...so have a plan and make part of that plan to stay away for the rest of the day. Even at light, if you spray the nest, hornets will follow your flashlight to try to sting you.
Are you guys using something like Spectracide Commercial Wasp & Hornet Killer? They don't come out the hole....nope...from 20' away :).
Lots of experience here.... |
Beer and Urine
I say drink a case of beer, get up close and whiz into that entry port circled in red. :)
http://forums.pelicanparts.com/uploa...1564877528.jpg Non toxic approach...what about that expanding foam stuff, fill that turkey with it, then set it on fire the next morning. My choice, fire, hair spray and lighter would work great. |
I have used serval brands (Spectacide and Hot Shot among others) that are good for 18-20 feet on the hornets here...and after an entire can, 4 or 5 hundred come out. About 100-150 fall and die and the rest chase my butt across the field. Wasps drop on the spot...but not hornets.
This is what they looked like when I sprayed mine: <iframe width="560" height="315" src="https://www.youtube.com/embed/cW7b4zvcDAg" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
I think I will pass on the urine stream or Great Stuff approach . Also not going to do the shotgun blast . So down to wasp spray or 🔥
you did not copy the part where I said use a stand-off weapon, which is what a shotgun is (for hornets) of course, the best thing is to nuke it from space |
Soak with diesel from above - light from below.
I've shot small nests with hornet/wasp spray and some always beat it out of there. And they pretty much know the location of the attacker so you better relocate quickly.
No advice on eradication. I let wasps live in peace as long as they aren't near a door. They eat insects. With the current SoCal daytime mosquito problem we need all the help we can get. |
There is only one true solution here: cold steel katana.
Please record a video for the rest of us. |
Plus a monkey roll.
It's a 55 or 56 only, not enough definition to say which. The 57 had a totally different dash. Bi-Five???? :) |
For the nest...the wasp sprays work. Once you get a kill, burn the paper nest. |
| All times are GMT -8. The time now is 04:43 AM. |
