Have you looked at the offerings from Ford Performance? May be a bit above budget, but you can be assured that Ford engineers have done the homework on putting these together. Note that these all have an all forged rotating assembly.
https://performanceparts.ford.com/engines/#302 Also, I agree with others about having to think about the entire drivetrain, brakes, and other components. This can become a slippery slope indeed. |
I had '65s with a 200 inline 6, a 260 V8 and a 289 V8. All ran like a scalded dog because the car was so light. Any would be pretty good for spirited driving.
The only version of that car that was a dog was the 170 inline 6. A 302 or smaller would be a great choice for the use you describe...but why not just rebuild the engine you have? |
In my life I have lamented some 'woulda coulda shoulda' decisions. The OP would not regret the 390 decision. The happiness of the economic choice fades. The comfort of the robust choice continues to please.
Drop another 10 or 15 grand (or more) into restomod upgrades and it would be fine. Stock and 390 is far too much. |
Totally agree. I have not once wished I had more power in my Elky. I could have dropped in a ton of power. Then spent a bunch fixing the drivetrain. |
390 is way too much power for that drive train.
I have never understood people's obsession with big numbers. I had a 986 standard Boxster. 217hp. TONS of fun. Perfect amount of power for the platform. 235, put a nice exhaust on it, and enjoy driving it. Think you will sink some $ into the chassis later, fine, go with 300. |
Thanks again guys, some really good input here.
I am still leaning towards the 235hp for many of the reasons stated here. The original engine was fine power wise, just getting tired. The 235 will be a nice upgrade with room to grow later; aluminum heads, better cam... Money is not the deciding factor, but it is a factor. With the ~$2k saved, I can get a better tranny and/or disc brakes. I did look at the ford stuff but waaaaay out of my league. Also thought about rebuilding original engine but have too many projects as it is, and money wise, its not too much more to get a drop in crate engine. |
Little more info:
http://forums.pelicanparts.com/uploa...1566484711.jpg http://forums.pelicanparts.com/uploa...1566484711.jpg Prices are wrong, the 390 increased by about a grand since I got this info. |
Wow, it is crazy how expensive Ford engines are. Way cheaper than Porsche for sure, but no wonder so many Ford hot rods and Chevy engines in them.
That 235 motor is not much different than an A Code with a Holly and alum intake.
Unless you are going to upgrade most aspects of your Mustang (which will cost more than a few dollars), you should stick with the 235 hp engine. Its torque curve, compared to the other two engines, works just fine for your intended use. No way in heck should you even consider the 390 hp engine.
My 66', pictured below, has about 325 hp and has numerous upgrades to keep me and the car in one piece: Radiator; Monte Carlo bar; roll bar; built T-5 tranny & driveshaft; frame connectors; traction bars; 9" rear end w/axles; performance suspension/brakes; etc, etc, etc. Even if you only upgrade to the 300 hp engine, you are definitely going to have to upgrade your car. http://forums.pelicanparts.com/uploa...1566489850.jpg |
Holy poop that is gorgeous!
| All times are GMT -8. The time now is 10:58 PM. |
