Whati s this tool?
Last weekend someone gave me this. I think it's some sort of pulley-holding tool, but I have no idea what the original application would have been.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I see you
looks like a MC rear hub tool for tightening the chain. Could also be an old shock adjusting tool.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Banned
to use when changing a garbage disposal?
Shock adjuster for a motorcycle.
1971 R75/5 2003 R1100S 2013 Ural Patrol 2023 R18 |
Spanner wrench used to loosen or tighten a specific thin nut size, like Varmint said
Coil over shock adjuster. Bike or car.
Keep talking, Im gonna put you in the trunk. |
It is a spanner. A little smaller than the one in a 911 toolkit
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Hook Spanner
Jon B. Vista, CA |
Technically speaking, if it’s for a motorcycle, it would actually rotate the threaded collars to adjust the spring preload on a rear shock.
Control Group
I have one sort of looks like that for the spring perches on the Miata
She was the kindest person I ever met |
In Porsche speak that tool holds the fan while you undo the nut. Except the handle looks short too be really useful. Also used to turn a spring perch on a coil over shock with the spring still inserted.
I have a half dozen of them.
down to jap bikes that run and a dead Norton |
Just thinking out loud
They give those away at planned parenthood.
83 944 91 FJ80 84 Ram Charger (now gone) |
Control Group
You slip the cylindrical lug nut doo dad over it to increase leverage
Recreational Mechanic
+1 on the 911 fan belt tool.
Or a Coilover adjustment tool but the radius looks too big.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
W/o being designed for a specific use, it's just a spanner wrench. Many are adjustable.
On a Norton commando from the seventies, that tool comes in the kit and it's used to make sure the large exhaust nut at the head stays tight, otherwise you strip the treads in the head and then you're f****d. Steel nuts, aluminum head.
nuts
