Right, springs are cheap. Make sure you order new hardware, I usually end up with something stripped/broken.
Platinum Member
.....unbolt the u bolts, slide in a leaf from a junkyard......
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
It isn't just us regulars reading here. AT this moment there are 63 members and 232 'guests'. Always think of a much broader readership. This ain't a private club.
You might oughtta check the front coil springs if they're as rusted as the leafs. They're even more problematic, I think, although they generally stay in place for a while, even if broken.
How much you guys want to bet this spring isn't fixed yet?
Scott '78 SC mit Sportomatic - Sold |
I see you
I had one snap in the Taco. I parked it until I could get it repaired. Same with my friends Tundra.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
