Ceiling: help
How could I hide or fix this.
Don’t want to scrape the ceiling It’s about 5 inches wide The room is not that big so I don’t think wide crown molding would look.
patch mud, tape, mud, texture, paint, done!
That sort of texture isn't that hard to replicate.
They sell texture in spray cans- never used it myself.
Rutager West 1977 911S Targa Chocolate Brown |
Cars & Coffee Killer
Two words:
Crack spackle.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Control Group
That is not out of a spray can probably, just sort of smush it and pull away from the surface.
like Chris shows
She was the kindest person I ever met |
Tape, float twenty min over it. Let dry and use drywall knife to knock down high ridges, and use topping compound, wet trowel, mush and pull from ceiling with a slight bit of twisting motion is the best way to describe it What the heck is that? Old access? |
Platinum Member
They should have taped over the joints.
I would use mesh-stick on tape and put it over those exposed joints. Then a thin layer of spackle to cover the tape, let dry. To texture, practice on some scrap. I could get pretty close to that by putting on a thin layer of spackle, then "pull it" by putting a flat blade on the wet spackle, and pull perpendicular away to raise the spackle. I suspect you could also get close, without tools, by pushing saran wrap into the spackle, and pulling it away. Or try a dabbing the spackle on with a damp sea sponge.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 09-15-2019 at 04:15 PM.. |
Wrong kind of texture
Exactly, usually using a thing that's like a brush that's been smashed flat.
I would tape and mud over the joints. Get a 3 lb tub of drywall mud and some mesh tape. Tape the joints and let it dry. Then put some mud on a board and thin it a bit with water. Stuff 4 or 5 plastic grocery bags inside another plastic grocery bag to make an applicator. Tape off the wall so you don’t get any mud on it. Dab your hillbilly applicator in the thinned mud and stomp it on the ceiling. You may have to experiment to get the texture you want. If you put up something you don’t like, wipe it off and start over. You can make it look great for not much $$ if you take your time.
. Last edited by wdfifteen; 09-15-2019 at 06:09 PM.. |
I screw that board down tight before applying any mud or mesh tape. If you don't, expansion and contraction will open that joint again. I bet there's nothing in the corner neither.
Edministrator
Install a ceiling cat.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
You do not have permissi
I've got somewhat the same type of texture, except in smaller star shapes.
They used a brush like this packed with thick mud. Smoosh in turn and pull away for a star. ![]() ![]() With a dragging action you might be able to blend into the existing random pattern. Or use a clumped rag? The rollers seem to give only a consistent pattern. I'm liking Easy Sand 45(min dry) for blending. It is dry but you can control the mix after stirring in a 14" tray (with 2" knife) and waiting a few for absorption. Knock off the surrounding and do a layer at a time w/dry time until flush. Should be almost no sanding. Last edited by john70t; 09-15-2019 at 08:04 PM.. |
Black light poster.
Chris 89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute |
unfortunately I am the one to blame for whats been done. I removed a bad fire place a few years ago and put up sheetrock on the one wall. I started to mud it but then stopped when I hit the wall of how to finish. yes I taped the corner but not the part on the ceiling yet. there was paneling on the rest of the room. I just pulled all that out and put up sheetrock and just finished all of that, now back to this mess. I may practice "texturing" on some spare sheetrock I have.
Brew Master
Sand back the edges of the "stomped" texture it makes feathering your taped edges easier and smoother, tape the joint, thin some compound, use the crows foot brush pictures and "stomp" the ceiling. Do a google search for "stomped ceiling" and you'll find some videos on how to do it.
Here's one
Nick |
Counterclockwise?
Hire someone to scrape the ceiling.
Can't see it costing more than a few hundred bucks. Then you never have to worry about it again.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
It came off in sheets. Repeat as needed. |
That ceiling stomp doesn’t appear to have a distinctive pattern. It’s only a small area, right? The grocery bag method I suggested would work fine. Practice on a board to find the method that gives your texture no matter what applicator you use. Even if you don’t get a perfect match you would be surprised how good it will look.
to me my texture looks like maybe they used a mop. I have heard that some have used a mop. cant seem to get anyone to come out and give me a price. I sheet rocked the entire room and was going to let someone else mud it but I gave up and just did it myself. scraping is still an option but I don't think I am up to all that ceiling work.
I'm with Bill
When I remodeled my master bath we wore out some walls and had to patch a 6'x6' section of ceiling. We had the same texture as you, my BIL used to work on a framing crew. He is one of those guys that wants to learn how to do everything everyone is doing. He learned how to do that texture, he called it a stomp mop.
We found one at home depot, it was similar to the one you see above. Here is one piece of advice, after you patch and paint that spot you will never stand 3' away from it staring at it again. So do not stress over perfection, get it pretty close and it will blend in.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
