T77911S's Avatar
first time laying tile
starting my tile backsplash tonight I think.
never done tile.
I laid the tile (mosaic) out on the counter on a short section and precut for the outlet and length and height. I hope this was not too big of a mistake, although I already have to go back and recut it. (yes keep cutting and its still too short).
what happened was when I started to do the other wall I found the gap between the counter and wall was too big so I put hardiboard on the back wall and that shortened the other wall by 1/4 inch, no big deal.
I have some of the other wall laid out also. one outlet box was close to the corner so I cut for that one, the other outlet was too far away to precut.
I practiced on a spare sheet of sheet rock. good thing, it was suggested to use a 1/4 by 1/4 trowel, that turned out to be too big and the mud was coming up between the small tiles. so I worked my way down to a very small "V" notched trowel that seems to be good,.
also got to practice how much thin set to put on.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-20-2019, 10:40 AM
Couple of pointers, if you don't already know. As you found out already, when doing walls that are adjacent, it's important to make sure the surfaces are level (to the counter top) and vertical to each other where they meet in the corner. You may have to make some pre-setting adjustments to square the corner and be certain the counter top is level.
Also, plan ahead on how you are going to cut the tile to fit the lengths. Can you fit a whole tile row at each end, or do you have to make a narrower row somewhere in the field to get the pattern to fit in the length? Sounds like you are using small tiles on a netting, so the trimming for fit may not be that difficult, just be aware.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-20-2019, 10:52 AM
I don't mind the tile part...have done a few small areas for myself.
I HATE the final step though....
GRRRRout
Old 09-20-2019, 11:12 AM
T77911S's Avatar
HAAAA.
that's why I have always avoided doing tile.........
oh I know things aren't square.
the counters are level and the cabinets are level. (mostly) that is the distance from the counter to the bottom of the cabinets is within 1/8 of an inch. surprising since I put the cabinets in.
its mosaic. so I don't think I need to worry about the ends being "centered" or even.. its on 12inch sheets with small rectangle tiles on it.
I will take a pic when I get home.
I have one end that will be exposed, the other end butts up to a cabinet so I can put molding over that end, but the end that is exposed, I am not sure how to finish it and not have exposed cuts. this is glass tile and I hate to leave a sharp cut edge exposed.
I have looked for rounded edge pieces like you see in a bathroom but I have not seen any.
RACE CAR:: sold
Old 09-20-2019, 11:28 AM
I see you
flatbutt's Avatar
GRRRRout
HA! I actually don't mind grouting. TEHO. Cutting always gets me though.
Old 09-20-2019, 11:44 AM
You use Schluter as per the included link. https://www.flooranddecor.com/schluter-installation-materials/schluter-jolly-brushed-nickel-anodized-aluminum-1-2in.-pvc-8-ft.-2-1-2-in.-tile-edging-trim-100183011.html?gclid=CjwKCAjw8ZHsBRA6EiwA7hw_sc935 DEJ7zEF3Sru-0EiD46rREVCmBSXoavpy2cDjdWwSDLpYmBqExoC798QAvD_BwE
Old 09-20-2019, 12:02 PM
What's the substrate, plaster, drywall, backer board? Fill low spot with thinnest, screed with a straight edge. let dry and start. Those low spots should be filled unless you butter the back to compensate for the valley
Old 09-20-2019, 12:30 PM
Information Overloader
A friend told me that with tile flooring if you don't immediatley fix a misalignment, it gets much, much worse. That's what rugs are for, he tells me.
Old 09-20-2019, 02:09 PM
Platinum Member
dad911's Avatar
HAAAA.
Post a pic of tile.
It drives me nuts when tile goes around a corner and they don't match the pattern, watch for that.
Where you start is important. I usually center the pattern at the range, then work out from there.
As Iceman said, we use Schluter trim alot. If it's glass tile like a brick/subway tile, you can flip the cut pieces around so the smooth side is out.
Old 09-20-2019, 02:12 PM
A930Rocket's Avatar
This.^^^^^^
Old 09-20-2019, 06:10 PM
peppy's Avatar
I used that metal edging on my back splash. It was hard to cut the 45s until I bought a blade for my miter saw.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-20-2019, 06:14 PM
Platinum Member
dad911's Avatar
They actually sell corners, but they are crazy expensive.
Old 09-21-2019, 06:27 AM
peppy's Avatar
The corners are probably cheaper than that blade I bought.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-21-2019, 06:50 AM
Platinum Member
dad911's Avatar
I usually use a (cordless)sawzall with a fine blade, or an oscillating tool, whichever is handy.
You can cut aluminum on a miter saw with any fine blade, just go slow. Also a good idea to back it up with scrap wood.
Old 09-21-2019, 07:25 AM
T77911S's Avatar
Here is my layout for cutting for cutting outlets
It worked pretty good
I precut for my last wall which was long and it worked perfectly.
I get stressed when working with something like thinset and workable time before it dries.
RACE CAR:: sold
Old 09-23-2019, 04:08 AM
T77911S's Avatar
It went well for my first attempt.
As usual I had a good plan. To use my laser level. But forgot. I did about 1/4 Friday night and we were very happy but as I kept looking At it the lines looked a little crooked which then I remembered the laser level.
Next day I set up the level. It really didn’t it not help.
The lines really aren’t bad and I am not sure they could be any straighter.
I thought a dark grout would help.
We opted for a lighter grout
RACE CAR:: sold
Old 09-23-2019, 04:17 AM
T77911S's Avatar
RACE CAR:: sold
Old 09-23-2019, 04:21 AM
T77911S's Avatar
I had a hard time with the grout at first
I had it too thick.
I thinned it out and it was easier. don't know if I had it too thin.
good thing my wife was there to clean up behind me because it was a mess.
RACE CAR:: sold
Old 09-23-2019, 04:23 AM
T77911S's Avatar
Post a pic of tile.
when I did the corners I cut one side flat and saved the small pieces I cut off.
on the other wall I had the sheet with the staggered ends. I used the pieces I cut off to match the tile from the adjoining wall
RACE CAR:: sold
Old 09-23-2019, 04:26 AM
T77911S's Avatar
I am considering doing the kitchen floor but I know my floor is uneven.
I remember when I have some vinyl put down years ago the installers just poured a bucket of self leveling stuff on the floor and just let it dry.
I have looked for the same stuff but the stuff I see says you have to trowel out.
another option is to paint my concrete floor for now.
I need to get the 930 engine rebuilt and I am spending too much time on the house.
RACE CAR:: sold
Old 09-23-2019, 04:31 AM
