Tahoe front end noise
Hi all
I've got a front end noise/vibration that i'm having trouble diagnosing. I'll try and keep it brief. I was going to DIY the front brakes on my Tahoe. I tried removing the guide pin on the lf caliper. It wouldn't budge (Canadian winters). I tried heat still no go. I gave up put the tire back on. From that moment now I have a vibration around 45 mph and higher. When the brake is applied the noise increases. I took the vehicle to my mechanic, he replaced pads, rotors. The noise is still there. I took it back and he said the front diff is the culprit and installed used one from salvage yard. The noise is still there. I still think it's something with the caliper but he says it can't be. I've used this shop for 20 years and this is the first time I've had an issue with them. Any ideas from the GM brain trust? Thanks in advance Brian |
You worked on the brakes. Something major changed then.
It's the brakes, and not the diff. The caliper might be stuck sideways with the brakes dragging and bouncing? Or a tire way out of balance from weights falling off? What else could have changed? |
You do everything to free it including putting that pig in a vice and laying heat to it with the dust boot removed. If nothing budges or it breaks you have to make the phone call. If it does move you clean the bore and the pin and re-grease. |
I keep thinking it's the caliper. Thanks John |
The shop recently expanded from 2 techs to 5 so I'm thinking someone less experienced did the brakes. I'll have to see what they say. Thanks Bob |
That car loves to eat front wheel bearings. Just another thought.
Gary |
Replace the front calipers. They’re cheap.
Tony |
^^^^agree^^^^
You never really said what it sounded like. Mine sounded like a plane getting ready to take off. It will usually change when turning one direction or the other. You've got one of the most dependable vehicles on the road. Congratulations.
I worked in GM service for about 9 years and was Service Manager for the last three of those. Most of us in service drove that same generation of truck. My shop foreman was over 300k on his and it still looked new. |
RF hub replaced in 2017 I removed the LF wheel yesterday when I installed winter tires. Aside from new pads/rotors the caliper looks like nothing was done. I couldn't budge one pin. I'm going to call them out on this tomorrow. In 20 yrs. this is the first time I've had an issue with this shop. They've expanded from 3 (including the 2 owners) mechanics to 6. |
It gets louder when applying the brakes heavily. I'm going tomorrow and see what they found. I'm going to see if they'll replace the caliper. |
update
Spoke to my mechanic today. He still can't locate cause of noise. This what he did today.
1 Removed drive shafts from transfer case and front diff. 2 Swapped front hub bearings 3 Removed rear diff. cover and checked rear diff 4 Checked main driveshaft Every time he tried something he road tested, the noise is always there. He's replacing he front caliper tomorrow, the poor guy is pulling what hairs he has left. |
Do you have fancy wheels? Some of them have a small alum. or plastic hub cover. My duramax came with these after market rims and I had the some noise issue at speed of over 60. My wrench pulled his hair out too and couldn't find anything. A few weeks later, I went to rotate these old tires, ha, the tire guy found the front hub cover a little loose. A turn of an Allen key, fixed the issue. Worth a look?
Both front hubs axles have been checked and one swapped out. My mechanic is running out of ideas |
Transfercase pump rub? Long shot but it shoun't only do it at speed?
He or one of the other mechanics changed the rotors and pads. At the time I questioned the caliper I'll know more tomorrow. |
What else can it be? Let us know what he finds.
Caliper hardware. Always replace the hardware with new pads. Apply grease or other to the pad backing to mitigate squealing. CRC is what I use.
I'm guessing you have one warped rotor.
| All times are GMT -8. The time now is 11:25 PM. |
