Tahoe front end noise
Hi all
I've got a front end noise/vibration that i'm having trouble diagnosing. I'll try and keep it brief. I was going to DIY the front brakes on my Tahoe. I tried removing the guide pin on the lf caliper. It wouldn't budge (Canadian winters). I tried heat still no go. I gave up put the tire back on. From that moment now I have a vibration around 45 mph and higher. When the brake is applied the noise increases. I took the vehicle to my mechanic, he replaced pads, rotors. The noise is still there. I took it back and he said the front diff is the culprit and installed used one from salvage yard. The noise is still there. I still think it's something with the caliper but he says it can't be. I've used this shop for 20 years and this is the first time I've had an issue with them. Any ideas from the GM brain trust? Thanks in advance Brian |
You worked on the brakes. Something major changed then.
It's the brakes, and not the diff. The caliper might be stuck sideways with the brakes dragging and bouncing? Or a tire way out of balance from weights falling off? What else could have changed? |
You do everything to free it including putting that pig in a vice and laying heat to it with the dust boot removed. If nothing budges or it breaks you have to make the phone call. If it does move you clean the bore and the pin and re-grease. |
I keep thinking it's the caliper. Thanks John |
The shop recently expanded from 2 techs to 5 so I'm thinking someone less experienced did the brakes. I'll have to see what they say. Thanks Bob |
That car loves to eat front wheel bearings. Just another thought.
Gary |
Replace the front calipers. They’re cheap.
Tony |
^^^^agree^^^^
You never really said what it sounded like. Mine sounded like a plane getting ready to take off. It will usually change when turning one direction or the other. You've got one of the most dependable vehicles on the road. Congratulations.
I worked in GM service for about 9 years and was Service Manager for the last three of those. Most of us in service drove that same generation of truck. My shop foreman was over 300k on his and it still looked new. |
RF hub replaced in 2017 I removed the LF wheel yesterday when I installed winter tires. Aside from new pads/rotors the caliper looks like nothing was done. I couldn't budge one pin. I'm going to call them out on this tomorrow. In 20 yrs. this is the first time I've had an issue with this shop. They've expanded from 3 (including the 2 owners) mechanics to 6. |
It gets louder when applying the brakes heavily. I'm going tomorrow and see what they found. I'm going to see if they'll replace the caliper. |
update
Spoke to my mechanic today. He still can't locate cause of noise. This what he did today.
1 Removed drive shafts from transfer case and front diff. 2 Swapped front hub bearings 3 Removed rear diff. cover and checked rear diff 4 Checked main driveshaft Every time he tried something he road tested, the noise is always there. He's replacing he front caliper tomorrow, the poor guy is pulling what hairs he has left. |
Do you have fancy wheels? Some of them have a small alum. or plastic hub cover. My duramax came with these after market rims and I had the some noise issue at speed of over 60. My wrench pulled his hair out too and couldn't find anything. A few weeks later, I went to rotate these old tires, ha, the tire guy found the front hub cover a little loose. A turn of an Allen key, fixed the issue. Worth a look?
Both front hubs axles have been checked and one swapped out. My mechanic is running out of ideas |
Transfercase pump rub? Long shot but it shoun't only do it at speed?
He or one of the other mechanics changed the rotors and pads. At the time I questioned the caliper I'll know more tomorrow. |
What else can it be? Let us know what he finds.
Caliper hardware. Always replace the hardware with new pads. Apply grease or other to the pad backing to mitigate squealing. CRC is what I use.
I'm guessing you have one warped rotor.
The new rotors (AC Delco) which I asked for were replaced. The LF caliper and bracket was replaced with new pads. The front hubs were changed as well (under warranty). I may throw it on jack stands next week if the weather co-operates and run it in 2 and 4 wheel drive to see if I can hear anything. Thankfully I'm retired and I have nothing better to do. :D |
Do you have a two piece rear drive shaft?
It makes the noise in gear and neutral. I even got it up to speed put in neutral and shut the engine off. The noise never changed, it gets more pronounced when applying the brakes. |
Does it have ABS? Either way, is there any feedback coming through the brake pedal?
No feedback pedal is normal but noise constant especially when braking. It sounds like big knobby tires, with either summer or winter tires. |
I had a noise, a slightly grinding and vibration noise, coming from mine when I drag the brakes gently coming down a hill. After about 20 min of it, gone, haven't heard it since. It been driven on the street and hwy for many months before. A small rock may have been stuck in the caliper because I once drove over a bunch of gravel on the ground from a cement truck in my Cayman. I was parked up hill so some of the small pebble must have kicked up, went into my caliper and made a grinding noise when brakes were applied. I couldn't believe it happened. It was such simple thing but how can a pebble get stuck from it kicking off the ground? Nuts. Yours is complete different problem. There are only so many things that turn and make weird noises?
Sort of related, my daughters AWD Escape had a noise I coldn’t Locate. Took it to my small one bay family shop, they drove the car for 15 min, put it on their lift and looked at all the components with a thermal camera. Replaced the ‘hottest’ item. Seems all A OK now..................Good Luck
Rich |
Have the lug nuts been tightened to specs?
I'll update next week when I take it back. |
Just did an F-150 where we replaced the guts in the differential. No difference. 45/50 mph the vibration started. No noise. Just shaking. U-joints and they demonstrated nothing odd. |
I was thinking the same thing. I'm going to ask them to check the front u-joint. The rear one was replaced 2 years ago. I'm even thinking the front axles. |
Some guy from a serious speed shop customer knew says matter of fact, it's your U joints (based on symptoms). It was. |
Final update
Finally got the truck back today. It's finally fixed.
Mr. Merk was on the right track Bob Kontak was correct. The rear u-joint by the rear diff. was the cause of the noise. It's unreal that the u-joint would carry a vibration from the back all the way to the front. Both u-joints were replaced, the truck drives like normal. Thanks to all that posted and offered suggestions. |
It definitely sounded like a u-joint but you said they'd been checked. I was thinking maybe carrier bearing on a two-piece shaft. My crew cab has a big single aluminum shaft.
Everybody wins! |
Sounds like the pro version of what many consumers do; something sounds out of whack on their vehicle at speed. So, instead of replicating the operating conditions, the owner or tech looks at the static vehicle and guesses what part could create a noise he doesn't hear, then goes on a spending spree. Many repair shops and all retail new car dealers sorta love that.
At some point in time, with repeatedly incorrect guesswork, someone (you) will tire of the guesstimates (or run out of repair funds) and either go elsewhere, up the volume on the stereo or yell at the wifie and/or dog. However, there's hope. Chances are, replacing random parts will eventually "fix" the cause of the complaint. :( Ain't in your best interest to go that route. Did your tech ever contemplate putting your vehicle onto a rolling road (e.g. dyno) to simulate the driving condition? With the car in "motion" he or his tech helper can lie prone and listen to the front end at 25 mph or whatever to at least pinpoint the noise source. Sherwood |
It all started when I was going to DIY the front brakes. I couldn't budge the front guide pins on the LF caliper. I gave up and put the wheel back on. The noise started at that point. I kept telling my mechanic that point. In the end the u-joint was going bad at the same time. Bad coincidence. I told him last week that I'd drive it and see what happens. I put the rear on jack stands and jacked the rear axle so the angle of the rear wheels would be close if on the ground. I put vehicle in drive and looked underneath. I saw the transfer case moving slightly back and forth. I lowered truck and went on the highway. The noise was present but if I hit a dip in the road the pitch of the sound changed as the truck went up and down. At that point I realized it's probably a u-joint. It must have been getting worse. He replaced the rear one by the rear diff. that was the issue. It was installed less than 2 years ago. The front one was also replaced. I only paid for the front diff which was bad, it made god awful noised in 4wd. All the other work including oil changes front hubs, and axle was free. I've been with this indy shop for 20 years. I'm still going to use them. |
| All times are GMT -8. The time now is 08:06 AM. |
