shotgun with SIGHTS?
i happen to know for a fact that you can miss a strutting turkey with a shotgun with consistency. total buck-fever.
i have an older BEATER Remington 11-87. i want to put a reddot sight on it. i researched those clamped brackets, but i cant imagine they are very rigid. now i'm thinking of letting my gunsmith drill and tap the receiver to take a picatinny rail. he said it would be easy. anyone do this? would it ruin the gun as a wingshooter for high flying sandhill crane?
poof! gone |
Brew Master
I think I'd let the gunsmith drill and tap the receiver. Not sure what you mean by clamp on mount. I'll have to look that up.
FWIW, I run a Weaver S2 on my Mossberg that I use for a slug gun and have never had a problem with it. It fastens to the side of receiver. I also run a different red dot for Turkey and my smooth barrel with an undertaker choke tube. I just swap out the red dots. Never had an issue with them being out of adjustment when I did it. After looking at pics I don't think I'd be afraid of the mounts for the 1187
Nick Last edited by cabmandone; 01-22-2020 at 08:58 AM.. |
I have a "sidesaddle" mount that I use on my dad's old 870 for slugs - it has a Weaver rail and mounts using the existing receiver screw holes.
I wouldn't have any qualms about drilling and tapping a "beater". I know an increasing number of guys who use red dots for turkey, geese and even upland hunting. If my astigmatism gets any worse I will try it myself.
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
I'd make sure your guy instals it w/ Vibra-tite or Rocksett.
New kid in town
I run a rifled barrel with a cantilevered scope mount like this on my deer gun. Not sure if they have the same in a smooth barrel...
![]() I'd also have no issue tapping your receiver. Be sure you get a red dot that will handle the recoil of the 12ga. Lots of stories of people using cheep red dots and having them lose 0.
I wish I still had 9111113443... |
Red dots, or any other sort of an optical sight on a shotgun, are akin to the same unholy contrivances on lever guns - they will make you grow hair on your palms. Best avoided.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Just my opinion - the barrel mounting on the 870 isn't great for holding zero with a receiver mounted optic. Probably not an issue unless you are trying to use slugs @ 100 yards +. Jeff - I used to agree with you regarding optics on shotguns. As my vision betrays me I'm starting to reconsider. I have peep sights on the lever guns and flintlocks but my effective range is getting shorter and shorter.
My friends call me, Top
I have peep sight on mine
Matt '87 924S |
Double Trouble
this.......https://www.amazon.com/B-Square-Remington-Serial-Shotgun-Saddle/dp/B0002IKRJE
it uses the holes for the trigger group pins. They work good, doesn't destroy the gun and is easy to undo. I've installed a few and never had any complaints.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base Last edited by targa911S; 01-23-2020 at 08:58 AM.. |
New kid in town
Brew Master
Red dot doesn't do much for bad eyesight. They have minimal magnification which is why you're supposed to have both eyes open when you use one.
Nick |
