It has a standing pilot with no 120 vac power requirement. I was surprised how light the old tank was considering we have hard water. The "Hydrojet" feature must help prevent sediment buildup over time. That and blowing down the tank on occasion helps too. |
Personally, I prefer an electric hot water heater in my homes as they are cheap, easy to install safely (no gas) and I can turn them off and on remotely from an iPhone ap by adding a simple control. New ones are much more efficient and you will almost always see a savings over the old one.
The ability to control it remotely is important to me as I spend my time between multiple homes and travel. I may not visit for weeks or months. I can leave mine off when I am away and turn it on en route...or when it gets cold enough to potentially freeze my pipes. Then I turn it and a water recirculation pump (that provides me with instant hot water when I am there) on remotely to keep the water in both the tank and the hot and cold water lines warm. I can turn both off when the temperature rises. |
Gas-powered water heating equipment is less energy-efficient than electric water heating equipment.
In order to reduce heat loss, these devices include heating elements that are fully submerged in the water. However, because a burner for a gas water heater is located outside the water tank, it is more vulnerable to external factors that encourage heat loss. |
Sent from my SM-G988B using Tapatalk |
Post #43 is a spammer.......
Tell you guys this. In my own and client's home, its tankless (Takagi)all day long. On our rentals, its all traditional gas, tank heaters because they are simple, reliable and requires no cleaning or maintenance. Easy to change out and lives outside where the men can get at it without having to go into the home. Our rule is to have the tank heaters change out every 14 years working or not, it goes so we eliminate that dreaded phone call when I'm out on a cruise across the Mediterranean with my hot, long legged 25 year old girl friend only to tell her I can't spend the night, must turn back and change out a water heater for my tenant. ;)
Being in the plumbing business I have access to any heater. I chose a Navien tankless for my home and the new shop/office we built a few years ago. I love the endless hot water.
The best ever heater was a copper tank Tragester from the 50's and 60's. I've seen them come out after a 25 year service life. In the 80's I had one in my own home that was manufactured in 1960. I digress. We sell AO Smith with very good results. |
The Heat Pump Hot water heaters are the most efficient but they are pricey and kind of noisy. Propane or natural gas tankless are great, but propane is pound for pound the most expensive fuel other than straight electric.
I'd go Heat pump if you can afford it. |
| All times are GMT -8. The time now is 07:04 PM. |
