License Plate screw removal
Bought a Suburban for the wife. Trying to remove the dealer license plate on the front bumper. Its held on by some screws that have a hole in the center with not way to use a screw driver and or bit. Anyone dealt or roved something like this?
Old 02-16-2020, 03:08 PM
picture?
Old 02-16-2020, 03:10 PM
dremel with a cutting wheel
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 02-16-2020, 03:14 PM
Brew Master
cabmandone's Avatar
You sure they aren't plastic rivets?
Nick
Old 02-16-2020, 03:23 PM
THat seems most likely to me, but without a pic, it's hard to say for sure.
Old 02-16-2020, 03:26 PM
I have used torx bits, Allen Wrenches and even a small slot head to try and get it to grab. However I'm not sure if this even has threads.
Old 02-16-2020, 04:38 PM
FPB111's Avatar
It is a rivet. Get a small punch and knock the center pin through. Catch it and reuse it.
Similar to this.
https://www.zoro.com/zoro-select-push-in-rivet-blind-316-in-pk20-61pr200000/i/G3399785/
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 02-16-2020, 04:43 PM
D idn't E arn I t
RANDY P's Avatar
drill it.
In the movies only bad guys sleep in king size beds.
Old 02-16-2020, 05:28 PM
Mike80911's Avatar
It looks like a tamper proof torx screw. They are torx bits with a hole in the middle you can find them at most auto parts stores and harbor freight
https://www.harborfreight.com/7-pc-star-tamper-proof-key-set-97471.html
89 930 Cab Black
11 Cayenne
Old 02-16-2020, 05:34 PM
Thanks guys. I m afraid if I drill it out that would damage the front bumper
Old 02-16-2020, 06:01 PM
SCadaddle's Avatar
a pair of side cutter pliers should do nicely.
Old 02-16-2020, 06:10 PM
Make Bruins Great Again
Por_sha911's Avatar
Carefully cut the plate so that you can slide it away from the rivet. You how have a small gap to saw off the rivet. Not easy but can be done.
Joe
Old 02-16-2020, 06:24 PM
jeez, the hacks who work at Chevy dealers.....https://www.camaro5.com/forums/showthread.php?t=83656
Old 02-16-2020, 06:27 PM
Edministrator
Steve Carlton's Avatar
Agree. A close up of the screw would help. It looks partially stripped already. You’re still going to have screw holes in your bumper cover.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 02-16-2020, 06:34 PM
Not a great picture but it does look like "tamper resistant" torx or allen.
Old 02-16-2020, 07:55 PM
Looks to me that rusnak nailed it with his link.
Old 02-16-2020, 07:58 PM
Yep, actual rivets. Looks like you're going to need a drill.
Old 02-16-2020, 08:10 PM
Take it back to your dealer and have them remove it.
Probably any dealer could do it. Maybe even a used car lot place.
Old 02-16-2020, 08:36 PM
Edministrator
How about a better close up pic? Maybe of another one that isn't as stripped?
O - $1
O - $2
O - $3
Old 02-16-2020, 08:44 PM
Arizona_928's Avatar
When I bought my tdi new. The dealer installed the plate with metal self tapping screws. Lol
Whatever
dolor et pavor
Copyright
Old 02-16-2020, 08:59 PM
