-   -   Question: Is there such a thing as a small walk behind tractor/bobcat (http://forums.pelicanparts.com/off-topic-discussions/1052993-question-there-such-thing-small-walk-behind-tractor-bobcat.html)
Tidybuoy 02-18-2020 10:59 AM
I recently had a new driveway done. In the process, I had the contractor dig up the asphalt that is behind my driveway (alley) and I am putting in gravel.
I need to level the dirt and remove a bit of dirt to accommodate a 4" deep geo-tex mesh that will help stabilize the gravel. This is going to require me to remove a couple inches of dirt that is currently very compact and difficult to remove. The area is fairly small at 20' x 30'
I'm wondering if there is such a thing as a small, walk behind, or riding mower size tractor that I could rent for both grading the area and spreading the gravel. I ordered 12 tons of gravel so I'm thinking that doing all this by shovel may take a while as well as do me in.
Any advice? I feel that a full size bobcat would be too big for this job.
This is the area:
http://forums.pelicanparts.com/uploa...1582052354.jpg
71T Targa 02-18-2020 11:09 AM
Yes, something like the Toro Dingo, or Bobcat MT55 can be rented at a lot of places.
I don't think either have a great load capacity so you'll be making a LOT of trips to move 12T
billybek 02-18-2020 11:10 AM
https://www.compactpowerrents.com/rental-equipment/mini-skid-steer/mini-skid-steer-roc-800-1000-lb/
Might be easier to hire it out but being a small job you might have trouble getting anyone to come out.
It would be fun to play with one of the mini skid steers, so that would be a good reason to rent one!
Tobra 02-18-2020 11:42 AM
You can rent a 5 hp roto tiller that you walk behind that would do that job fine.
wdfifteen 02-18-2020 12:10 PM
A small tractor will move gravel, but what are you going to use to loosen the dirt? Nothing small is going to move compacted dirt. You would have to break it up with a roto tiller first, then move it. I would get a full sized bobcat and be done with it if I were you.
Sooner or later 02-18-2020 01:07 PM
Have some fun. Rent a Bobcat
RWebb 02-18-2020 01:20 PM
some walk behinds can take a backhoe to break u compacted dirt; switch to a bucket for loading/transport
is there access for a sit-on Bobcat or similar where the photo was taken from, or otherwise?
gordner 02-18-2020 01:20 PM
a small bobcat would do that just fine in a space that size, and will easily level the compacted dirt. Not the walk behind small unit, but even the smallest of the backpack style loaders will do that no problem. You sure don't need a full sized one that you couldn't turn in that space.
cabmandone 02-18-2020 02:59 PM
Nope! Never heard of such a thing. :D
http://forums.pelicanparts.com/uploa...1582066750.jpg
cabmandone 02-18-2020 03:02 PM
Not sure how much space you really have to work but a T450 size Bobcat is pretty nice and will do more than the MT I posted the pics of. Just so you know, the 85 means 850lbs lift capacity. Toro makes a Dingo that will lift 1100 IIRC and it's a stand on machine too.
The MT55 has a lift capacity of 550 lbs. Toro, Vermeer, Bobcat all have stand on/walk behind machines.
I'd rent a T450 size track machine. They're compact in size but have good pushing/digging power. The MT's are nice but you're limited to such a small bucket that they take a while to get the work done.
Zeke 02-18-2020 03:57 PM
Rental yards might not have the real small stand up loaders because they aren't meant for real tough jobs which some renter probably thinks he can do and save some money. Nope, he breaks it instead. So smart money gets a real tractor that will handle what the bucket allows.
Like this:
https://www.laxequipmentrental.com/w...tal-photo1.jpg
The difference in rental costs is minimal. You can pull this around on a trailer with a 1/2 T truck.
Scott Douglas 02-18-2020 04:11 PM
My brother rented at tractor two weekends ago to muck out a stall.
http://forums.pelicanparts.com/uploa...1582070868.JPG
Then he moved up the hill to move a pile of dirt.
http://forums.pelicanparts.com/uploa...1582070905.JPG
Two hours in, he shut it down to take a break and the tractor started pissing hydraulic fluid. It hadn't leaked until it was shut off.
http://forums.pelicanparts.com/uploa...1582070989.JPG
That ended our weekend fun with the tractor.
Lessons learned prior to this adventure were to always get the insurance when renting a tractor. Break downs can be pricey.
porsche930dude 02-18-2020 05:06 PM
thats what i was thinking. its not hard to shovel once the soil is loose
MBAtarga 02-18-2020 05:20 PM
I'd love me a Toro Dingo. I was able to borrow one from the landscaper prepping the front yard for sod. He left two overnight on the property and I got the go-ahead to use one. Moved some mulch around and also was able to do some light grading to improve drainage around my shop.
I've since rented the same from HD with all attachments to do some trenching for drainage lines.
He's got 12 tons of gravel to spread as well.
Baz 02-18-2020 05:31 PM
If you find find someone with a small machine with tracks like Nick posted #9 above.
Someone who would take cash and do small jobs.
That would be ideal.
Doing it yourself is "do-able" but would be my second choice.
Try calling a site contractor in your area and see if they know someone - or the bulk material yard you're getting your gravel from. They may know someone.
RWebb 02-18-2020 05:37 PM
https://www.youtube.com/watch?v=W5P4i-aytws
cabmandone 02-18-2020 05:57 PM
Zeke,
Believe it or not, the MT85 is more capable than the S70.
wdfifteen 02-18-2020 05:58 PM
So you rent a tiller to loosen the soil and then shovel the dirt around and then spread 12 tons of gravel? Geeze, I'm retired and even I don't have that much free time.
cabmandone 02-18-2020 05:59 PM
I know a guy..... :D
porsche930dude 02-18-2020 07:22 PM
Well when I get an idea like this I usually get right to work with what iv got on hand and it gets done before anyone even has time to plan out the "right way to do it" get 2 or 3 helpers and itll be done in no time
RKDinOKC 02-18-2020 07:25 PM
I use a rear tine tiller, wheelbarrow, and shovel. They all fit through the stockade fence gates.
Indescikov 02-18-2020 09:23 PM
ASV RC30 or PT-30 Small track loader 3500 lb. Footprint of a 4x8 sheet of plywood. 31.5 hp
Tidybuoy 02-19-2020 09:25 AM
Last night I framed the area with 8x8 treated timbers. Sorry, no pics yet. Once I got the space framed and the timbers level, I discovered I really only need to remove the dirt from two edges. And, after soaking pretty well, the dirt scooped up pretty easily. I got about 1/3 done and will work on this every night this week. To me, its exercise and I'm a bit impatient to wait for the weekend.
I also have a mini-roto-tiller and I will try that tonight.
That said, my gravel (3/4 crushed granite) is being delivered on Thursday and I should be ready to start spreading by this weekend. I will looking into renting a mini skid for this as I know it won't be easy. 20 years ago I had 19 tons of gravel delivered for out front and I told the guy to just dump it in a pile - that was a mistake as it took me 3 months to spread it and I was a lot younger then.
BTW, this is for an alley behind my house - actually a driveway alley that dead ends at my garage.
Tidybuoy 02-19-2020 09:28 AM
We think alike.
Seahawk 02-19-2020 09:46 AM
Looks great...nicely done.
One tip that I tell folks on their first couple of runs with a mini-skid: Keep the RPM's low on the engine to start, the bucket will move slower as will the skid itself. Nothing good happens fast in the beginning and you can get acquainted with the skid better.
I have a lot of hours on front end loaders. I prefer 1500 to 2000 RPM on my tractors when working in close quarters.
Learn the bucket reverse level move and you are good to go.
Enjoy.
Zeke 02-19-2020 12:05 PM
Originally Posted by cabmando (Post 10757148)
Zeke,
Seems to have an edge indeed. I was probably looking at the MT55 which by comparison to the others mentioned is kind of a lightweight. Anyway, the MT is a track style and the S70 is on rubber, so for dirt work the MT's might be easier to work the dirt leaving less tracks.
Tidybuoy 02-20-2020 10:44 AM
Making progress. I'm surprised how much I've gotten done with a shovel. It helped that I bought a 4 wheel gorilla dumping wheel barrel. Working every night till midnight...and I can still stand up straight :)
Need to scoop out a little more dirt around the edges and dryout the area. Then I'm going to rent a "Jumping Jack" compactor. After that, plastic liner, geomesh grid, and crushed rock.
Here's the area:
http://forums.pelicanparts.com/uploa...1582224039.jpg
http://forums.pelicanparts.com/uploa...1582224065.jpg
http://forums.pelicanparts.com/uploa...1582224259.jpg
cabmandone 02-20-2020 10:51 AM
Good grief! I must just value my back more. I would have paid $200 for a rental and got the job done in a few hours.
Tidybuoy 02-20-2020 10:54 AM
I totally agree but I can't rent anything until the weekend. This is my evening exercise project. And, I've got family coming to town this Saturday so I'm feeling like I want it to be somewhat completed.
RWebb 02-20-2020 11:46 AM
exercise is good
oh, BTW - would you like to move 1.5 tons of rock down my hill??
cabmandone 02-20-2020 01:00 PM
You mean you have help arriving and did the work yourself? :D
David 02-20-2020 01:12 PM
My neighbor has a walk behind skid steer. Here he is doing some drainage work in my backyard:
http://forums.pelicanparts.com/uploa...1582232936.JPG
Tidybuoy 02-20-2020 01:19 PM
I'll have the area graded and prepped by the end of this weekend. I plan to rent something for moving the gravel.
dad911 02-20-2020 07:19 PM
Slip the dump driver $20 to tailgate spread it.
Tidybuoy 02-21-2020 09:48 AM
It's never that easy....gravel is already here. Dug out about another inch last night and took the advice here and rototilled first. I'm almost don't but man....I'm sore today.
Progress:
http://forums.pelicanparts.com/uploa...1582307152.jpg
Problem Area - Hard as Hardpan:
http://forums.pelicanparts.com/uploa...1582307203.jpg
Need to remove about 1: more
http://forums.pelicanparts.com/uploa...1582307240.jpg
porsche930dude 02-21-2020 03:08 PM
too late now but i always wanted to do something in this type of pavers. I actually tried casting my own once but it didnt work with regular concrete. got a pic of your fancy wheelbarrow?
http://forums.pelicanparts.com/uploa...1582326382.jpg
Tidybuoy 02-21-2020 05:04 PM
This is the one that I bought. Holds about double a regular wheelbarrow.
http://forums.pelicanparts.com/uploa...1582333429.jpg
Tidybuoy 02-21-2020 05:08 PM
Actually, this is the exact model. A little bigger than my previous pic
http://forums.pelicanparts.com/uploa...1582333693.jpg
porsche930dude 02-21-2020 06:04 PM
looks pretty stout. Iv got 3 or so regular wheelbarrows different sizes and quality. I actually prefer the cheap ones because they are lighter but cant take as much material. The main thing i dont like about any of them is the single wheel they tip over when loaded heavy. I always wanted to add another wheel to see how it works with two but never get around to it
