Battery corrosion
My sons girlfriends Mercedes ML 500 battery died. I was in the area but I didn’t have any tools. We called AAA and they provide a battery service. This poor guy had a rough time getting the shroud and negative terminal off. We find the negative terminal needs to be replaced and some wiring unrelated to the battery but hidden behind the battery starting to corrode. Is there a way to stop corrosion on these wires? She wants to keep the car for one more year until she graduates from law school. Thanks in advance.
Old 03-13-2020, 12:09 PM
rfuerst911sc's Avatar
A good smear of dielectric grease will retard/prevent further corrosion . Any auto store will sell it .
Old 03-13-2020, 12:34 PM
AutoBahned
RWebb's Avatar
the negative terminal on the battery (post)??
or the cable to the battery?
Old 03-13-2020, 12:37 PM
Control Group
Tobra's Avatar
maybe baking soda solution to neutralize acid, then fresh water to remove that prior to grease
Old 03-13-2020, 12:45 PM
wdfifteen's Avatar
+1
That's the way to do it. DO NOT let baking soda get into the battery.
Old 03-13-2020, 05:13 PM
The negative cable not the terminal and some thicker wire on the firewall.
Old 03-13-2020, 05:25 PM
Thanks, I’ll give that a go.
Old 03-13-2020, 05:28 PM
chapo's Avatar
Exactly, baking soda, rinse, grease. Do not let the grease get between the contacts, coat it after all of the connections are made. My Fi50 by the beach always grew stuff on it until I did it this way.
Patrick
Old 03-13-2020, 05:46 PM
Make Bruins Great Again
Por_sha911's Avatar
If the corrosion is in the strand cable itself, treating the end won't do much. Replace the cable.
Joe
Old 03-13-2020, 07:15 PM
That’s my plan. However there is a fat wire behind the battery connecting to a terminal on the firewall that is corroding. That one isn’t easy to replace. I was hoping to slow the corrosion until she gets a new car.
Old 03-13-2020, 07:56 PM
