-   -   Pilots-Experimental Aircraft Question (http://forums.pelicanparts.com/off-topic-discussions/1057016-pilots-experimental-aircraft-question.html)
Eric Coffey 04-05-2020 08:47 PM
Originally Posted by NeedSpace (Post 10812744)
Also, I don't intend to build the plane myself.
Just keep in mind that if you don't build at least 51% yourself, then you won't qualify for the DIY maintenance capability (repairman's cert) that the original builder had. You'll only be able to do limited "routine" maintenance, just as if it were a normal/cert'd A/C. As such, it would negate one of the big perks of home-builts.
