fred cook's Avatar
Removing lead buildup from barrel compensator
I use a screw on comp on a Ruger 22/45 pistol. Over a couple of years, the lead deposits finally built up to the point the openings were nearly clogged. What is/are the best ways to remove such deposits?
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-11-2020, 08:17 PM
Jim Bremner's Avatar
What about a #1 drill bit twisted in by hand?
Old 04-11-2020, 10:31 PM
id10t's Avatar
Unscrew comp from barrel and replace?
Anything you do to work on getting the lead out will just be exposing you to more and more of the stuff.
Old 04-12-2020, 05:49 AM
I see you
flatbutt's Avatar
Got a sonic bath?
Old 04-12-2020, 07:04 AM
Gon fix it with me hammer
svandamme's Avatar
if you can get it, blob of mercury will dissolve any lead.
So ideal to restore a high end rimfire match barrel
or that compensator
just be careful to recover it since both lead and mercury are toxic.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-12-2020, 07:42 AM
fred cook's Avatar
Good thoughts, all! Thanks. I wound up using a small diamond bit in a Dremel tool to remove the lead. To minimize exposure to the lead dust I wore a mask and worked over a dampened paper towel to catch and hold debris. This worked quite well and had the offending deposits removed in short order. I will be more observant in the future and not let the deposits build up!
FEC3
Old 04-12-2020, 07:54 AM
