-   -   how far can I cantilever a 4 inch concrete slab ? (http://forums.pelicanparts.com/off-topic-discussions/1060460-how-far-can-i-cantilever-4-inch-concrete-slab.html)
fastfredracing 05-08-2020 10:08 AM
I bought a small mixer, and have learned just about enough to be dangerous . I am making a small patio off the back of my house . Almost done, but I need to overhang a retaining wall by about 11 inches to meet where my other deck will be .
This will be a 4x8 slab, and the long side is where I will need the overhang.
There is a similar slab on the other side , that is 6 inches thick, and overhangs by 6 inches .
Any ideas ?
Iciclehead 05-08-2020 10:08 AM
Any rebar in it?
Dennis
fastfredracing 05-08-2020 10:17 AM
Of course! I was thinking about doubling up on rebar. I also have a bunch of sheets of heavy wire mesh, that I have been laying into the slabs .
island911 05-08-2020 10:21 AM
Originally Posted by Iciclehead (Post 10857016)
Any rebar in it?
Dennis
And where (top or bottom) does it exist?
Gretch 05-08-2020 11:05 AM
only pre-stressed concrete slabs can be cantilevered, Fred.
Poured concrete shears at a 45 degree angle.
red-beard 05-08-2020 11:16 AM
^^^This
flatbutt 05-08-2020 11:21 AM
Somewhere at sometime I recall reading about a length over depth ratio for concrete overhang....I think I'm remembering this correctly but don't bank on it.
rusnak 05-08-2020 11:54 AM
Maybe instead of doubling up rebar, space the lattice half the distance and dowl pin it into the deck and go with 6" slab.
MBAtarga 05-08-2020 12:43 PM
I don't understand the vision:
http://forums.pelicanparts.com/uploa...1588970573.gif
fastfredracing 05-08-2020 12:47 PM
Ill snap up a picture tonight.
jgreen 05-08-2020 12:49 PM
Frank Lloyd Write knows....
908/930 05-08-2020 02:04 PM
Not sure if this would work but, if you drop in 3' x 3/4 dia threaded rod with bent J end into the slab about every 12" starting 4" from the end, and cap the outside cantilevered end with 1/2" steel plate and tension it after the concrete has fully cured (30days). Possibly would keep it under compression so it will not break off. Pretty sure you want to be near centre of thickness of the slab and at least 2" from the surface, so real tight with 4" slab.
vash 05-08-2020 02:21 PM
Can you tie it to the other deck?
I’m not quite picturing it. How high is this overhang? (Off the ground).
TimT 05-08-2020 02:35 PM
Now that's just not true ...
Many bridges you drive over every day have cantilevered components.. I.e. outside stringer to fascia is a cantilevered component.. The wheel path is designed to be closer to the support...
However.. considering a 4 in slab there is not enough depth to install the reinforcement needed..
And an 11 in overhang is nothing.. hardy a cantilevered deck..
http://forums.pelicanparts.com/uploa...1588977129.jpg
If you're worried increase the depth f the slab to perhaps 6-8 in prior to the overhang to allow for proper placement of reinforcement
wdfifteen 05-08-2020 04:22 PM
You can’t. Even a slab well reinforced by rebar is going to flex. A cantilever will flex in tension (the top will try to get longer). Concrete is great in compression but sucks in tension. It will crack and crumble and fall apart and you will be sad. You’ll need a thicker slab. In other words, “Yer gonna need a lot more than four inches, bub.” You’ve probably heard that before.
A930Rocket 05-08-2020 04:27 PM
To my feeble brain, I just don’t think a mixer making small batches of concrete would help either.
vash 05-08-2020 04:31 PM
There is also failure in creep.
I think it can work if the failures are simply some cracking. But Tim is right. I’ve seen overhangs. We usually post tension in the transverse direction. Plus we have lots of rebar. Lots. Lots.
I’d love to see a pic of what Fred’s got cooking over there.
I always joke with my concrete venders. If I do a pour at my house, I’m pulling a mix design from my files. I’m pouring a high strength mix. Driveway cracks? Sure. My tree roots are gonna struggle.
daepp 05-08-2020 07:19 PM
And of course, at Fallingwater his cantilevers sagged after time. And his patron (the furniture guy - can't remember his name) actually had him double the amount he'd been planning to use.
rusnak 05-08-2020 07:24 PM
http://forums.pelicanparts.com/uploa...1588994636.jpg
<iframe src="https://player.vimeo.com/video/8472796" width="640" height="480" frameborder="0" allow="autoplay; fullscreen" allowfullscreen></iframe>
<p><a href="https://vimeo.com/8472796">Saving Fallingwater</a> from <a href="https://vimeo.com/user2837250">Bill Doorley</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
Crowbob 05-08-2020 07:31 PM
Almost every one of his homes is unlivable, outrageously expensive to maintain and ridiculously expensive to build.
But they certainly are beautiful.
daepp 05-08-2020 07:33 PM
What about tapering the last 11 inches thicker - to maybe 6 or 8 inches, and before you pour epoxy in dowel pins into the other slab. Maybe use a higher psi mix as well. I really don't think you'd ever have a problem with it unless you plan to drive across it etc.
daepp 05-08-2020 07:36 PM
Side note: we had one of our (just finished unoccupied 2 story house) slabs get undermined by a freak flash flood. It cleared out nearly 8 feet under the corner of two exterior walls. The slab was 4: with #3 bars on 18" centers each way. We could measure no deflection on the walls that met at that corner, and I even stood under it just, cuz.
I wouldn't have believed it if I hadn't seen it, but then again all the old-timers always told me we were overbuilding these days.
Evans, Marv 05-08-2020 09:42 PM
Fred. If you're overhanging a retaining wall, is there a possibility you can install steel braces anchored to the retaining wall to support your overhang? I'm no engineer of course.
javadog 05-09-2020 05:10 AM
Dowel pin the two slabs together where they meet. You should be fine. Use good concrete. Mixers are for making mortar for masonry. Good concrete comes from concrete plants in big concrete trucks.
