how far can I cantilever a 4 inch concrete slab ?
I bought a small mixer, and have learned just about enough to be dangerous . I am making a small patio off the back of my house . Almost done, but I need to overhang a retaining wall by about 11 inches to meet where my other deck will be .
This will be a 4x8 slab, and the long side is where I will need the overhang. There is a similar slab on the other side , that is 6 inches thick, and overhangs by 6 inches . Any ideas ?
No left turn un stoned |
Any rebar in it?
Dennis |
Of course! I was thinking about doubling up on rebar. I also have a bunch of sheets of heavy wire mesh, that I have been laying into the slabs .
Information Junky
And where (top or bottom) does it exist?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
only pre-stressed concrete slabs can be cantilevered, Fred.
Poured concrete shears at a 45 degree angle. |
canna change law physics
^^^This
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I see you
Somewhere at sometime I recall reading about a length over depth ratio for concrete overhang....I think I'm remembering this correctly but don't bank on it.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Maybe instead of doubling up rebar, space the lattice half the distance and dowl pin it into the deck and go with 6" slab.
I don't understand the vision:
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Ill snap up a picture tonight.
Frank Lloyd Write knows....
Not sure if this would work but, if you drop in 3' x 3/4 dia threaded rod with bent J end into the slab about every 12" starting 4" from the end, and cap the outside cantilevered end with 1/2" steel plate and tension it after the concrete has fully cured (30days). Possibly would keep it under compression so it will not break off. Pretty sure you want to be near centre of thickness of the slab and at least 2" from the surface, so real tight with 4" slab.
87 930, |
Can you tie it to the other deck?
I’m not quite picturing it. How high is this overhang? (Off the ground).
poof! gone |
Navin Johnson
Many bridges you drive over every day have cantilevered components.. I.e. outside stringer to fascia is a cantilevered component.. The wheel path is designed to be closer to the support... However.. considering a 4 in slab there is not enough depth to install the reinforcement needed.. And an 11 in overhang is nothing.. hardy a cantilevered deck.. ![]() If you're worried increase the depth f the slab to perhaps 6-8 in prior to the overhang to allow for proper placement of reinforcement
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 05-08-2020 at 03:37 PM.. |
You can’t. Even a slab well reinforced by rebar is going to flex. A cantilever will flex in tension (the top will try to get longer). Concrete is great in compression but sucks in tension. It will crack and crumble and fall apart and you will be sad. You’ll need a thicker slab. In other words, “Yer gonna need a lot more than four inches, bub.” You’ve probably heard that before.
To my feeble brain, I just don’t think a mixer making small batches of concrete would help either.
There is also failure in creep.
I think it can work if the failures are simply some cracking. But Tim is right. I’ve seen overhangs. We usually post tension in the transverse direction. Plus we have lots of rebar. Lots. Lots. I’d love to see a pic of what Fred’s got cooking over there. I always joke with my concrete venders. If I do a pour at my house, I’m pulling a mix design from my files. I’m pouring a high strength mix. Driveway cracks? Sure. My tree roots are gonna struggle.
poof! gone |
And of course, at Fallingwater his cantilevers sagged after time. And his patron (the furniture guy - can't remember his name) actually had him double the amount he'd been planning to use.
David 1972 911T/S MFI Survivor |
Information Overloader
Almost every one of his homes is unlivable, outrageously expensive to maintain and ridiculously expensive to build.
But they certainly are beautiful. |
