fastfredracing's Avatar
I need to level up for a footer, and concrete pad, what tool do I need ?
Transit? Rotary lazer level? This is not my wheelhouse, but I'm going to give it hell anyhow .
No left turn un stoned
Old 05-24-2020, 04:29 PM
gduke2010
gduke2010's Avatar
yes and yes. You could use either.
Old 05-24-2020, 04:34 PM
gduke2010
gduke2010's Avatar
With a transit or builders level you need another person with a stick or tape measure
Old 05-24-2020, 04:35 PM
Platinum Member
dad911's Avatar
Need more info.
House footing? Laser or good transit.
A/C pad? 2' level.
Pour the footing loose enough, and it's self levelling.
Old 05-24-2020, 04:44 PM
Navin Johnson
TimT's Avatar
Um you don't need anything fancy or expensive..
And if you need to turn corners... simple math and trig....
https://www.johnsonlevel.com/News/LineLevels
some 3 4 5 maths... and hey you can build pyramids!
'69 911 GT-5
'75 914 GT-3
and others
Old 05-24-2020, 04:47 PM
You do not have permissi
john70t's Avatar
The old way was to dig a sealed trench and measure up from water.
Old 05-24-2020, 04:56 PM
vash's Avatar
Make a water level? Bucket and a length of clear hose. And a tape measure of course.
poof! gone
Old 05-24-2020, 05:04 PM
This. Unless you have a laser level to make life a little simpler.
Old 05-24-2020, 05:30 PM
get it close enough, fill it with rebar and let the concrete find it's level.
make sure the j bolts are high enough.
Chris
the more i learn, the less i know
Old 05-24-2020, 05:55 PM
Banned
just a pad ? why level water will pond slope to drain away
if for something that needs level string level should work at mini cost
Old 05-24-2020, 06:12 PM
vash's Avatar
Don’t over water the concrete mix. The higher the water:cement ratio, the weaker the final product. That why high strength mixes has water reduction agents to give you a workable mix and a strong final product.
poof! gone
Old 05-24-2020, 06:25 PM
Brew Master
cabmandone's Avatar
I use a rotary laser level. First shoot the road, then shoot the lot, then determine where I want the foundation. Hopefully the two readings allow me to have the floor of the building above the road. If you were closer I'd pop by and do a few readings for ya!
Nick
Old 05-24-2020, 07:06 PM
wdfifteen's Avatar
Originally Posted by dad911 View Post
Need more info.)
+1
What are you actually doing?
Old 05-25-2020, 03:29 PM
A930Rocket's Avatar
A cheap builders level will work. A laser level is overkill, but doing it by yourself, it’s handy.
For quick work, I use this. It’s a handheld level.
Old 05-25-2020, 03:58 PM
MBAtarga's Avatar
I rented a transit, tripod and stick for a day from a tool rental location. I think it might have been $25. Well worth the money to do the job right.
Mark
'83 SC Targa - since 5/5/2001
Old 05-25-2020, 06:41 PM
vash's Avatar
FRED, if you need one of these, i'll mail you one.
in my opinion they are are just okay. i just used one an hour or so ago, and i got anywhere from 24-30 inches elevation between two spots 25 feet apart. good enough for government work, but not for what you want.
i'm better with a string line and a 4 foot level, but it requires a friend. that isnt a knucklehead.
poof! gone
Old 05-27-2020, 02:03 PM
Unregistered
sammyg2's Avatar
A hundred years ago, I was using a transit to set elevations of sole plates for a large brown boveri steam turbine-generator.
The tolerance was +- .005" which is about as good as I could hit it with that tool. I used a 12" starrett 98 level to nail the actual level once I got the elevation dialed in.
The pipe fitter foreman asked if I could shoot in the elevation on a pipe support next to the foundation.
I said sure, and checked his print for the elevation and did the basic maths. But it didn't list the tolerance. So I says to him, how close does it have to be?
He said it has to be dead nutz, within a quarter inch.
I'm, sorry what were we talking about again?
Old 05-27-2020, 02:21 PM
Thanks for the replies, and offers guys, I am building a 20x40 quonset hut garage at my house . Im going to try to do it all myself . Dig , form, and pour the footer, pour the pads, and erect the building Im thinking about doing the floor in 4 smaller pours .
I did some smaller pads this spring to get a feel for how much concrete I think I could handle single handed.
I have string and a 4 foot level, but a friend who is not a knucklehead, could be a tough one . Im using my 14 year old for cheap labor .
Old 05-27-2020, 03:13 PM
MBAtarga's Avatar
You know the saying - you get what you pay for!
Mark
Old 05-27-2020, 06:22 PM
wdfifteen's Avatar
So you are doing basically a two wall foundation for a quonset hut? Pouring the footer and the wall at once? No forming above ground level? What?
I'm not familiar with code quonset hut construction. Do you pour a footer and build up/pour a wall to above ground level and bolt your quonset structure to it, or just pour a footer, bold the structure to it, and back fill over the steel?
Old 05-27-2020, 06:48 PM
