I don't mind putting some money into it, just not a ton.
Marv, thanks for your offer, but as dad911 mentioned i could get an Engine for $100 or so. Shipping on your B&S would probably be more, not to mention the hassle. But I will keep it in mind, just in case. So I guess the way to go is toss the above mentioned concoction down the spark plug hole and let it seep. I've got nothing to lose. |
I don't know the size of the engine on my log splitter off the top of my head....but 8hp is huge....think mine is 5 or so. Gotta be a lot of older ones around for virtually nothing.....or...
Nicoderm patch :D |
Umm, I know you don't want to get too involved in working on it but it's really easy to take the head off and scrape all the carbon off the head, side valves and piston. That's if it's like the B&S motor I played with years ago. It may go better with a bit of a clean up. Or maybe you could see down the bore to see if it's scratched up from broken rings. Just an idea - I'm no expert.
I'd suggest you look into the Mississippi "Executive Model" Log Splitter (otherwise known as "Ben Hur, Done That") as seen here. Works like a champ!
http://forums.pelicanparts.com/uploa...1590552750.jpg http://forums.pelicanparts.com/uploa...1590552750.jpg |
Sorry in advance for the dumb question, but have you verified that the oil level is not too high?
Get an electric motor for that thing. |
It's soaking now with ATF and Marvel Mystery Oil. It's what I had on hand. Gave it a couple of turns by hand and will let it sit for a couple of days. If no better I'll try the Seafoam. |
I'd just put the Marvel right in the crankcase and run it some.
Same with the Seafoam if you go that route. |
Not sure 'bout the HP rating but ....
79cc engine - $50 (enfield) Brand new in box https://hartford.craigslist.org/grd/d/enfield-79cc-engine/7125562290.html http://forums.pelicanparts.com/uploa...1590608256.jpg EDIT prolly 3hp, too small. |
Or ...
This one might be closer, bet you could get it fer $25 but it might need a bit more tinkering
http://forums.pelicanparts.com/uploa...1590609051.jpg http://forums.pelicanparts.com/uploa...1590609051.jpg |
There would have to be some combination of carburetor, hydraulic drag, engine connection to the hydraulic pump, etc. issues to blame to make me want to repair that engine. Buy a replacement motor, spend a few minute with the hydraulics (fluids, hoses, engine/hydraulic pump interface and roll. Good news is that log splitters hold their value better than a '72 911S. Fix it. |
Stop putting your 40:1 chainsaw gas in it, it's a 4 stroke !
Plus he can pipe the exhaust into gopher holes and have an excellent killer of gophers. Might even get rich by starting a business of eliminating gophers.
or maybe the gophers will like the oil, and use it as ....
| All times are GMT -8. The time now is 06:55 PM. |
