Old log splitter smokes like crazy. Do any "snake oils" work at all?
I have a really beat up mess of a log splitter. I'm not looking into putting any serious money into it as I only use it very infrequently and it's ugly. But it works. The problem is it smokes like mad (blue smoke). The smoke doesn't bother me, the beast could seize up and explode for all I care, but, I have neighbors. Nobody has complained yet but I'd like to reduce the amount of smoke if at all possible. I've read about Marvel Mystery oil, Restore, Wynn's Stop Smoke, Lucas 10001, and a slew of others. I've also read about people pouring Bon Ami cleanser in the spark plug hole to reseat the rings. Do any of you have any experience with anything store bought or home remedies?
So you fog for 'skeeters once in a while...no complaints... no problem...
Mebbe someone here is actually helpful :D |
Well, one person does complain. My wife. She works the lever as I handle the wood.
What kind of engine are we talking about here?
A Briggs and Stratton or something like that or a bigger engine? |
http://forums.pelicanparts.com/uploa...1590523335.jpg |
What if you up the viscosity of oil a couple steps?
Probably won't do any good. But the price is right. Another thought: Could it be a stuck oil control ring? If so, some sort of detergent/solvent/stress loading might improve it. Italian tuneup? I'm not hopeful of this either. Good luck! |
LWJ, I'm using straight 40w the thickest i can find around here. Burns right through it.
I'd put some Marvel in it. That stuff will loosen up the oil control ring if it's stuck.
And you re-install the cover while it's running?
Suspect its just tired but worth a try. |
can you take a length of pipe and extend the exhaust pipe past the person working the lever? like downwind of the wife?
sorry, i buy my firewood in those plastic packages. :) (i dont, i use an AXE - okay, that is an exaggeration as well) |
a 6.5 horse Harbor Freight horizontal shaft engine is $100.
He doesn't want to spend any money on it if possible.
Seafoam in the gas and crankcase would probably be a good bet too. |
Starless. I have an old B&G, 8 hp. engine (horizontal shaft) you can have for shipping cost. It's from a tiller. My father used to be a prison guard, & had it rebuilt in the prison shop. That was early to mid '80s. It's been stored & I've carried it around with me for decades. Never been fired up. I've never gotten around to selling it, so it can go to a good cause if you're interested. PM me if you want it.
What? STP no longer around?
I don't mind putting some money into it, just not a ton.
Marv, thanks for your offer, but as dad911 mentioned i could get an Engine for $100 or so. Shipping on your B&S would probably be more, not to mention the hassle. But I will keep it in mind, just in case. So I guess the way to go is toss the above mentioned concoction down the spark plug hole and let it seep. I've got nothing to lose. |
I don't know the size of the engine on my log splitter off the top of my head....but 8hp is huge....think mine is 5 or so. Gotta be a lot of older ones around for virtually nothing.....or...
Nicoderm patch :D |
Umm, I know you don't want to get too involved in working on it but it's really easy to take the head off and scrape all the carbon off the head, side valves and piston. That's if it's like the B&S motor I played with years ago. It may go better with a bit of a clean up. Or maybe you could see down the bore to see if it's scratched up from broken rings. Just an idea - I'm no expert.
I'd suggest you look into the Mississippi "Executive Model" Log Splitter (otherwise known as "Ben Hur, Done That") as seen here. Works like a champ!
http://forums.pelicanparts.com/uploa...1590552750.jpg http://forums.pelicanparts.com/uploa...1590552750.jpg |
Sorry in advance for the dumb question, but have you verified that the oil level is not too high?
Get an electric motor for that thing. |
It's soaking now with ATF and Marvel Mystery Oil. It's what I had on hand. Gave it a couple of turns by hand and will let it sit for a couple of days. If no better I'll try the Seafoam. |
I'd just put the Marvel right in the crankcase and run it some.
Same with the Seafoam if you go that route. |
Not sure 'bout the HP rating but ....
79cc engine - $50 (enfield) Brand new in box https://hartford.craigslist.org/grd/d/enfield-79cc-engine/7125562290.html http://forums.pelicanparts.com/uploa...1590608256.jpg EDIT prolly 3hp, too small. |
Or ...
This one might be closer, bet you could get it fer $25 but it might need a bit more tinkering
http://forums.pelicanparts.com/uploa...1590609051.jpg http://forums.pelicanparts.com/uploa...1590609051.jpg |
There would have to be some combination of carburetor, hydraulic drag, engine connection to the hydraulic pump, etc. issues to blame to make me want to repair that engine. Buy a replacement motor, spend a few minute with the hydraulics (fluids, hoses, engine/hydraulic pump interface and roll. Good news is that log splitters hold their value better than a '72 911S. Fix it. |
Stop putting your 40:1 chainsaw gas in it, it's a 4 stroke !
Plus he can pipe the exhaust into gopher holes and have an excellent killer of gophers. Might even get rich by starting a business of eliminating gophers.
or maybe the gophers will like the oil, and use it as ....
| All times are GMT -8. The time now is 02:10 AM. |
