LinkBack | Thread Tools | Rate Thread |
I don't mind putting some money into it, just not a ton.
Marv, thanks for your offer, but as dad911 mentioned i could get an Engine for $100 or so. Shipping on your B&S would probably be more, not to mention the hassle. But I will keep it in mind, just in case. So I guess the way to go is toss the above mentioned concoction down the spark plug hole and let it seep. I've got nothing to lose.
JUAN '80SC Targa |
I don't know the size of the engine on my log splitter off the top of my head....but 8hp is huge....think mine is 5 or so. Gotta be a lot of older ones around for virtually nothing.....or...
Nicoderm patch
Umm, I know you don't want to get too involved in working on it but it's really easy to take the head off and scrape all the carbon off the head, side valves and piston. That's if it's like the B&S motor I played with years ago. It may go better with a bit of a clean up. Or maybe you could see down the bore to see if it's scratched up from broken rings. Just an idea - I'm no expert.
I'd suggest you look into the Mississippi "Executive Model" Log Splitter (otherwise known as "Ben Hur, Done That") as seen here. Works like a champ!
Unregistered
Sorry in advance for the dumb question, but have you verified that the oil level is not too high?
Try this, it was developed for one lunger boat rental engines back in the 30's. Run it and then change the spark plug, that might cure it.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
weekend wOrrier
Get an electric motor for that thing. |
It's soaking now with ATF and Marvel Mystery Oil. It's what I had on hand. Gave it a couple of turns by hand and will let it sit for a couple of days. If no better I'll try the Seafoam.
JUAN '80SC Targa |
I'd just put the Marvel right in the crankcase and run it some.
Same with the Seafoam if you go that route.
Scott '78 SC mit Sportomatic - Sold |
It burns as much oil as gas! Well, not quite, but close.
JUAN '80SC Targa |
Unregistered
Not sure 'bout the HP rating but ....
79cc engine - $50 (enfield) Brand new in box https://hartford.craigslist.org/grd/d/enfield-79cc-engine/7125562290.html ![]() EDIT prolly 3hp, too small. Last edited by sammyg2; 05-27-2020 at 12:56 PM.. |
Unregistered
Or ...
Unregistered
This one might be closer, bet you could get it fer $25 but it might need a bit more tinkering
Motor is tostitos...gone.
There would have to be some combination of carburetor, hydraulic drag, engine connection to the hydraulic pump, etc. issues to blame to make me want to repair that engine. Buy a replacement motor, spend a few minute with the hydraulics (fluids, hoses, engine/hydraulic pump interface and roll. Good news is that log splitters hold their value better than a '72 911S. Fix it.
1996 FJ80. |
Stop putting your 40:1 chainsaw gas in it, it's a 4 stroke !
Yes, and they were all a waste of money. If you really use it infrequently and having it function on demand isn't that important, run the exhaust into a bucket of cold water to condense out the oil and keep jammin' the wood to it until it throws a rod.
. Last edited by wdfifteen; 05-27-2020 at 04:35 PM.. |
Plus he can pipe the exhaust into gopher holes and have an excellent killer of gophers. Might even get rich by starting a business of eliminating gophers.
Marv Evans '69 911E |
AutoBahned
or maybe the gophers will like the oil, and use it as ....
