So in the photo I posted of the carburetor, (motorcycle carb, fwiw), what product or method of repair would you guys use? :cool:
Is a replacement expensive or un-obtainable?
devcon 10760.....what dan said.... i have heard peter dawe patch engine block holes with this stuff in a pinch. in my race gear box he fashioned a novel oil entryway for cooling and tap/died it for a high pressure AN fitting. the stuff is unbelievable.
Do you just want to plug the hole? If so, what is the tube's function? It's not an assembly that I am familiar with. |
Can you shape a washer to curve around that tube and then drill to hole size spec? Wave washers are thin and might work, already curved though easy to flatten and recurve. Or McMaster Carr has a huge selection of shims that might work in filling and resizing that hole. |
I think a washer would disrupt the airflow too much in that particular case. I would just JB and be done.
That's too bad. I use .1mm (4 thousandths) on up McMC shims when putting Guard LSDs in 915s. Thought that kind of shim thickness might work and be a stronger more permanent repair than JB Weld alone.
Is there a brass tube that fits in the hole or is that the orifice for a metering needle? I ask because it would be good to understand what forces are given to that hole. Or, how in the world did that break like that?
It very much looks like a slide valve motorcycle carb. Edit: Sorry, I just saw that you said it was a MC carb in post #42. So, it is the needle hole. Weird break. |
I’ll post pictures tomorrow of the offending parts and it will all make sense. |
Denis that was really bad luck the previous owner :rolleyes: put a hole in it.
I think it's a very good candidate for JB Weld or one of these greater alternatives. |
| All times are GMT -8. The time now is 02:21 PM. |
