Refrigerator stopped working-HELP!
Well, Mercury must be in Gatorade or something wrt appliances today. First Scott’s dryer and now the fridge at the cabin stopped working. The freezer seems to still be working OK but fridge not cold. A whole bunch of food about to go bad.
It’s a plain Jane GE, still humming away but not cold. Any help appreciated!! http://forums.pelicanparts.com/uploa...1594595846.jpg http://forums.pelicanparts.com/uploa...1594595846.jpg http://forums.pelicanparts.com/uploa...1594595846.jpg |
Can't help ya on this one. Need to now outlet temps to even start guessing.
The evaporator coils are under the floor of the freezer. Take the floor out of the freezer (it's held down by a few screws) and see if the evaporator is iced up. If it is, the defrost heater or the defrost timer might have gone out. Either way, you might get it working again if the coils are iced up and you can thaw them.
One friend suggested that the thermostat quit working. I would not know where to look for that. I have no way to measure temps but it’s basically warm inside. No refrigeration taking place. Thanks
A new fridge is a joy. Automatic defrost etc. And they use a lot less electricity than that one.
The problems, in order: 1. Defrost timer stopped working. The result was the evaporator iced up and often broke the defrost heater (a glass tube with a heating element in it). The symptoms are evaporator coils clogged with ice. 2. The defrost heater burned out. The symptoms are evaporator coils clogged with ice. 3. condenser coils were clogged with dog hair and other crap. They are pretty good at dispersing heat even with a lot of crap on them, but there is a limit. 4. evaporator fan stopped working. The evaporator fan is in the freezer, under the freezer floor. 5. condenser fan (under the refrigerator, draws air over the condenser coils) burned out 6. compressor start relay not working 7. compressor burned out The freezer may still seem to be working because the evaporator coils are in the freezer and the compressor and cooling system are still working. It sounds like an air handling problem. The refrigerator section depends on the evaporator fan blowing air over the evaporator coils and sending it down to the refrigerator. If the evaporator coils are clogged with ice the freezer will stay cold but the evaporator fan can’t move air over them to send down to the fridge. The first thing you should do is take the floor out of the freezer and see if the coils are free of ice and see if the fan is running. |
Go on You Tube - punch in your model. Something may turn up that helps. That's usually my first stop.
Alright! If you're gonna make it difficult, pull the fridge out, turn the thermostat to its coldest setting, make sure the compressor is running, touch the small copper line and see if it's hot. Touch the bigger one and see if it's cool. You mention that it's "humming away" which indicates the evaporator fan is working. How does the air feel coming into the refrigerator? Does it seem like the fan is moving enough air? If not, evap is iced up. Let it defrost and try restarting the fridge. If you have some frozen stuff in the freezer and a cooler, toss the perishable stuff from the fridge in the cooler with some frozen stuff from the freezer and let the fridge defrost.
Post a pic of model and serial #. WD covers most of it. There is also a fan that moves air between the freezer and fridge. If it fails the fridge gets warm. All the food probably needs to come out and go in ice chests while you troubleshoot and diagnose.
Is your refrigerator running?
…….. Ok, lets not go there but a good place to start with WD's list. Get some ice and throw all the frozen stuff in a cooler. Unplug and open the fridge and freezer door. After a few hours, plug it back in and see if it goes back to normal operation. Defrost timer. Very possible. Defrost termination switch. Could be Evap fan. Maybe That style of fridge there shouldn't be any fancy damper systems like some of the newer fridges have. Never hurts to roll out and clean the condenser. Small line hot bigger line cold (to the compressor). Refrigeration is something we all take for granted until it doesn't work. Much like running water and electricity... |
You guys are the best! I’ll unplug it and defrost it, see if that helps.
I unplugged it and emptied the freezer, floor is a skating rink. Can’t even remove those screws until I get it thawed. The vents on the floor are almost completely blocked w ice. Pretty sure this is the problem, thanks a million. Especially WD but everyone who posted. :)
Use a hair dryer to speed the process..
Clean the Freezer out, shop vac underneath and the coils. Make sure the freezer set is good. Thats how I milked ours until I spent 3500 on a new one!
The suspense is killing me! Fess up man! did ya get it working?
So I got a total of four "in all my years I have never seen that before" on repair from experts. My personal record. What I loved about that fridge is is had an cold air outlet in the corner near a shelf. If I put a beer right in front of it it would chill it to have just a few ice crystals in it. Never freeze the beer, but just the perfect cold. |
We had a compressor go out while under extended warranty and was replaced at no charge. The repair guy said people should ALWAYS buy the extended warranty when buying new. He said if this had been a service call and replacement it would have been a $400-600 bill.
You should NEVER (almost) buy extended warranty when buying new.
Thanks again for the help, everyone. This place rocks for most any technical/mechanical problem on earth. :) |
Damn it. You posted again before I got to ask if your refrigerator was running.
I had a warranty on my furnace. Called the insurance company to get it fixed. Turned out the place they called wasn't even a repair shop - just a guy who had some contractors on the line that he could sub the job out to. He sent out a guy from 60 miles away because he was the lowest bidder. He got here, looked at the furnace, and declared that the problem was with the vent and vents aren't covered under the policy. I had to pay the $100 minimum charge and then find a local guy to come and fix it. Turned out the problem was a cracked heat exchanger. A friend of mine had a water pump put in his VW Scirocco under warranty. They paid for the pump and labor to put it in, but would not pay for a broken stud, gasket, antifreeze, shop supplies or shop supplies. He saved some money, but they didn't "cover" the repair. |
Most people who buy an extended warranty would end up with more $$$ in the long run if they didn't buy one. An extended warranty is basically an insurance policy, with an unbelievable mark-up and a large portion going to commission. Almost pure profit. Like double or better. Crazy expensive if you buy from the seller. Iffn you are nervous about being in the very small percentage of people who would benefit from buying an extended warranty, you can buy a much, much cheaper version if you look around. At credit union fer example. On a used car you can usually get the same extended warranty from a credit union fer about half of what a stealer would charge. |
Fwiw, the evaporator and fan were not under the freezer floor on this one but behind the rear wall of freezer. I did still have to remove the freezer floor, though, to defrost it. It was iced solid where it is supposed to have air passages(?), large baffles going front-to-rear.
Here is a photo of it, (before cleaning but after defrost), it was frozen solid everywhere under floor and up the back wall to the bottom of the evaporator. You can see the floor section on the kitchen floor in second photo: http://forums.pelicanparts.com/uploa...1594651450.jpg http://forums.pelicanparts.com/uploa...1594651450.jpg And a shot of the lake, just for the why not: :) http://forums.pelicanparts.com/uploa...1594651707.jpg |
Good news is that it you can't fix it you can always use it as a boat anchor.
Thanks again. SmileWavy |
Most so-called extended warranties on vehicles would require a complete engine or transmission grenade w proof of perfect maintenance to break even. |
I have a 5-6 year old Samsung that had the same problem as Speeder, except the ice forms around the fan on top, stops the fan, and the fridge gets warm.. Seems like it's a very common occurrence. |
Appliance and electronic warranties are hit and miss and usually overpriced and not worth it. I go case by case, though. At Magnolia (in Best Buy) they have an all-encompassing warranty with Best Buy's reputation behind it. I took it on my 4K TV setup because it wasn't expensive and I like the idea of the Geek Squad coming to my house to troubleshoot and replace as necessary. Some credit card benefits will double your warranty- I got a complete refund on a an early HD TV through that.
On cars it gets complicated. A lot of them are aftermarket "extended service contracts" that dealers sell with huge markups. I'm a fan of factory warranties if you know you're getting a good deal, which isn't easy to know. It is a form of insurance, of course. Just because somebody makes money on it doesn't mean it's not a good deal for you. What if Porsche offered an IMSB warranty for 10 years for $1,000, hypothetically? CPO warranties on cars are good deals. The dealer does it up front for a reasonable price, the cars tend to qualify for low APR financing as well. With Volvos, you can extend them, too. You can wind up with a car that has warranty for 10 years from the original sale date with either 100,000 miles or unlimited miles. They sell for about $3,500-4,000 including a healthy markup. For what they cover, plus peace of mind over a $15,000 engine or $7,000 transmission, I think they're a good deal. You will recover a big chunk of what you put in, anyway on some repairs. |
For every person that receives more benefit than they paid it there are 10 that pay in more than they receive in benefits. |
Is that what you wanted to hear? |
Like anything it depends on the details; the product and the coverage. Blanket answer of no, never buy doesn't really address the issue. |
We have a similar refrigerator in the garage. It is about 18 years old. Same problem as OP’s 3 years ago. Watched a repair guy do the defrost. I now do it proactively each spring. No other problems since the.
| All times are GMT -8. The time now is 11:54 PM. |
