a man has got to know his limitations.
damn..
my Toyota Tacoma fan only blows on High. its a known issue. a simple resistor swap out. however, it is so common that Toyota updated their resistor. the new part appears to come out of the newer 3rd generation tacoma. GREAT! i bought the parts thinking it was an easy job of splicing it in to the harness. but we have a problem. i have to match four wires. the colors dont match up!! hahhaha. you should have seen me try to tackle my brothers boat trailer lights in my youth. 4 wires matched to 4 wires. i bet mathematically, there are 4137 different combinations. i showed the pic to my wife and she just started laughing at me. good times!! i'll farm this job out. i have fried a harness before, and it was not fun.
poof! gone |
Tru6 Restoration & Design |
weekend wOrrier
We've passed down all we know. A thousand generations (of wire splicers) live in you now......
Well.. you could break out an ohm meter, find the common wire, then ohm out the rest...
I think it is ground and 3 levels of resistance for the 3 fan speeds. If you screw it up kinda bad, the positions on the selector will be in the wrong spots (ie full speed in the middle). If you screw it up really bad the motor will spin in reverse. However I think it is hard to fully dicker up the job.
Surely dr google has a wiring diagram however. At least it is not an elise, took me 2 full weekends to replace the resistors. It involves removing body panels and ALL of the AC system.
84 930 18 Cayman GTS |
I had the same problem with my 2010 Tacoma. Can't remember how I did it, think I found the answer on TacomaWorld forums.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
i dont do maiden voyages.
poof! gone |
Trade-up to a Honda Ridgeline?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
poof! gone |
Just splice it and get it over with. You know you're going to trade it in on a new Bronco anyway......
I like to think man has no limits
No left turn un stoned |
AutoBahned
I like to think man has no gimlets
Unregistered
Giblets?
AutoBahned
Is this the one?
https://www.tacomaworld.com/threads/replacement-of-hvac-blower-motor-resistor.8310/page-8
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
That might be it. Thanks.
poof! gone |
Any thread authored by Vash with a title such as this, I gotta open up and enjoy.
Did not disappoint...
Always take the high road, it's far less crowded - Charlie Munger |
74' 911 w/3.2L (sold) 95' 993 C2 Triple Blk Cab. 02 Honda Superhawk (sold) 2018 Toyota Tundra Limited 2004 CRF250X |
