porsher
aston@ultrasw.c's Avatar
Aerodynamics Question
I know that to answer this question properly I will need a CFD workstation and someone who knows how to use it. However, I am hoping that someone with sufficient experience can apply general principles and get me 80% of the way there.
The project is to install an oil cooler in the front fender of a 928, with a surprisingly good duct
I will have more questions later but lets start with the inlet: should it poke out into the airflow (lower) or be flush to the contour of the front bumper (upper)?
In both cases the back of the light housing will be cut open to approx 11 x 4.” The turn signal will be relocated to the inboard end of the housing.
Here's a quick look at the back end
Thanks in advance for any help or advice you can provide.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-16-2020, 05:51 PM
Arizona_928's Avatar
Should be plenty... the mk4 tdi puts the intercooler in that location but lower.
As for location... That will destroy the oil radiator with tire/road debris.
Put it in a box/cover, or remote it to under the trunk w/fan.... That one will be the easiest option.
What's your engine? Dry sump conversion?
dolor et pavor
Copyright
Old 07-16-2020, 06:10 PM
Information Junky
island911's Avatar
You will find the highest pressure in front of the front wheel.
Not only do you have dynamic pressure there (from fwd motion) but also from the top of the tire bringing air fwd and down. ... and then all that air gets pinched off between the tire and the road.
IOW, a vent going upwards from under the nose....
Old 07-16-2020, 08:40 PM
porsher
Thanks.
The duct will fully enclose the cooler.
The current idea is to capture high pressure air from the front and exit via the upper surface of the fender in a low pressure area. Approximately from the top of the tire, then forward 12." Outlet is a 12" x 9" APR extractor vent.
My first thought was make use of existing holes before cutting additional ones.
A lower inlet is a good idea, especially if it capitalizes on air caught by the splitter.
Like this (only had a pic of the 911 handy)
79 928 Race Car
Old 07-17-2020, 08:08 AM
3rd_gear_Ted's Avatar
Airflow out the back of the cooler is just as important as the front.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 07-17-2020, 09:42 AM
porsher
Lets say we have a square sheetmetal duct 12" x 12"
If the corners had a radius Vs square would airflow improve?
Say r of 0.5" or 1" or 1.5"
Or is the gain negligible such that the extra difficulty in fabrication is not worth the effort?
79 928 Race Car
Old 07-17-2020, 01:20 PM
porsher
Hey Arizona_928
I am embarking on an LS project down in Tucson.
Maybe I could buy you a beer?
79 928 Race Car
Old 07-17-2020, 01:23 PM
Originally Posted by aston@ultrasw.c View Post
Hey Arizona_928
That's awesome. If you need some issues ran through another set of eyes, or general Q's. I probably won't make it down to the Dity T until it cools off though!
dolor et pavor
Copyright
Old 07-17-2020, 06:25 PM
Information Junky
island911's Avatar
The cooler is likely the biggest flow hit (restriction). The corner radii are not likely going to affect the flow much.
Old 07-17-2020, 11:53 PM
Shifter's Avatar
Take a look at the oil cooler design on the 944 S2 and 968 cars. They have the oil cooler mounted under the bumper on the passenger side. I bet Porsche spent a bunch of money on the air flow characteristics that might save you some time.
Old 07-18-2020, 01:04 AM
You do not have permissi
john70t's Avatar
A scoop to create ram-air might help or hurt at higher speeds, and there is probably a swirl-vacuum in the wheel well for pulling air out(I don't understand the dynamics there), but also consider a couple separate layers of screening in the airflow for stone chips and other road detriments.
Old 07-18-2020, 02:42 PM
The 951 oil cooler is giant brick. The S4 928 trans cooler is a long cooler. I Should have a spare of both that I can snap a pick of.
dolor et pavor
Copyright
Old 07-18-2020, 02:45 PM
