-   -   Ever remove a Gib Key? (http://forums.pelicanparts.com/off-topic-discussions/1068968-ever-remove-gib-key.html)
wdfifteen 08-01-2020 01:19 PM
Originally Posted by unclebilly (Post 10969802)
This seemed like a good solution...
http://forums.pelicanparts.com/uploa...1596300270.jpg
Still no luck.
Since you are so far into it, how about torching the rod the slide hammer is connected to off of the tube and welding on a 1/2-20 nut. Screw a bolt into the nut and against the end of the shaft.
sammyg2 08-01-2020 01:36 PM
Like Freiburger says, fix it with fire.
cabmandone 08-01-2020 01:54 PM
Those keys are fairly soft aren't they? Couldn't you grind it flush, drill it, take a small chisel and release it from the sprocket, pull the sprocket off, and then put a new key in?
cabmandone 08-01-2020 02:03 PM
Or make a puller by taking a piece of plate steel, drill a hole in it, grind a flat spot to grab the head of the key, drill and tap three holes, insert bolts long enough to contact the sprocket plus some threads and tighten each bolt until the key pulls out.
MBAtarga 08-01-2020 07:57 PM
Turn the gib key into a bolt on the bottom of a motorcyle. It will fall right out.
1990C4S 08-02-2020 07:58 AM
Connect your stick welder directly to the key, ground on the chain drive. Pulse the machine on/off until the key is cherry red. Spray it with penetrating oil while it's hot.
unclebilly 08-02-2020 09:09 AM
http://forums.pelicanparts.com/uploa...1596384542.jpg
Still no love from this piece of 5hit. Heat is next.
Baz 08-02-2020 09:41 AM
I have one of those big pry bars - they are about 6' long and weigh a lot. Somehow if you could get one of those in there along with heat to the sprocket and ice on the key.......
unclebilly 08-02-2020 10:16 AM
^^^ I started with the pry bar. If I don’t get it, I’m cutting the sprocket to remove it.
The time invested already exceeds the value of the sprocket.
cabmandone 08-02-2020 10:50 AM
I still think a drill and chisel would get it. Maybe some heat on the head of the pin and let it transfer through the pin. Surprised the two bolts applying pressure and the puller didn't work.
Jandrews 08-02-2020 11:23 AM
I love/hate challenges like this. I know that feeling of frustration well. Being WAY, WAY beyond any reasonable effort to resolve what should be a simple task. The good news is that is feels THAT much better when you do claim victory!!!
If that sprocket is readily available, I'm in heat first, cut second camp.
Good luck. Keep us posted!
JA
dlockhart 08-02-2020 11:54 AM
http://forums.pelicanparts.com/uploa...1596394438.jpg
cabmandone 08-02-2020 12:12 PM
Have you trying changing up the order of the curse words you're using? Or maybe throwing something at it in disgust? :D
LEAKYSEALS951 08-02-2020 12:25 PM
You probably have, but have you sourced a replacement gear yet? Seems like 1/2 the time I can find a direct replacement, and the other 1/2 I have to fabricate something.
If you aren't having luck, try talking like this guy when you're working on it. Pure frontier jibberish. He's a trip! :D
<iframe width="560" height="315" src="https://www.youtube.com/embed/Xuw5SLuraS8" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
KFC911 08-02-2020 12:27 PM
You need to go buy a new sprocket and key. Then give the old key one last gentle pull....it'll probably jump out :D
Bigtoe32067 08-02-2020 12:30 PM
If you have a tractor supply near you they usually have a pretty good selection of sprockets and such for farm implements.
Good luck
Tony
wdfifteen 08-02-2020 06:41 PM
Sounds just like the agricultural engineers around here!
unclebilly 08-02-2020 06:55 PM
Sometimes you have to get western...
http://forums.pelicanparts.com/uploa...1596419600.jpg
http://forums.pelicanparts.com/uploa...1596419721.jpg
billybek 08-02-2020 07:05 PM
Atta boy, Scott...
A930Rocket 08-02-2020 07:23 PM
Did you do the right one?
The upper one looks like it needs replacing first. 😂
http://forums.pelicanparts.com/uploa...1596421416.jpg
