We don't know what's wrong with the engine yet, but if it's serious it sound like the car is totaled and there's the salvage value or mechanics special/LS conversion material. The shop that has it hasn't identified what's wrong with the engine, they need to pull it to see, and to me that's suspicious. RMG said they would be able to diagnose it for $200 by running a compression check and opening up the oil filter. There's a small chance that it could be fixed in an affordable way. That's why I suggested the owner take it there. If he has AAA, it won't cost much.
Who are the people paying $20k for a 996 cab w 200k on the odometer? :confused:
Because I sense a hell of a business opportunity. They absolutely grow on trees for $10k or less w half the miles. Plain 996 coupes are very low on the demand side, cabs are close to worthless. |
Life is too short at this point. I'll either buy a Porsche I want or happily not own one. :) |
But why not buy an actual Chevy? If you like an LS engine, you like Chevys.
That is not a very intelligent thing to say Denis
The guys at RMG know their stuff and are great to deal with. They did the PPI on my 356 and it was better than advertised. My 996 C4S at 104k is likely going to need a trans rebuild. I was getting ready and have the parts to renew the struts and mounts but noticed a howl on the highway and metal flakes in the fluid which was pretty dark. It goes in for a professional opinion in a few weeks. At this mileage and given the relative condition of the car I'll fix it. At 200k I don't know that I'd be putting a new motor in unless I was really committed to owning the car long term and the rest was in very good shape and fresh.
Living in SoCal 200 HP is all that is needed. To use 400 HP you might get a chance now and then to spurt on the freeway for less than 10 seconds, or drive 1 to 2 hours to an open road. And lastly one can always track a car and have some HP fun if that's your game. I had as much fun as anyone lying one inch off the ground with a whopping 16 HP doing 100 MPH at Big Willow. Had less fun in an early 2.2 MFI 911 with 180 HP and only about 10 seconds a lap faster at the same track. No, I wouldn't want a Chevy lump in the back. I rode one time in a Jag XJ coupe with a conversion and wished I never had. Having owned Jags that put a real sour taste in my mouth. The guy here building the Subaru "Blasphemy Build" certainly aptly named his project AFAIC. |
That just seems like an awful lot of work and money invested to loose 50 hp. you would probably have to re tune to get it to run correctly , blech.
I've got no problem with an LS conversion, but you better love your finished project, because it is still not inexpensive . Start adding up all the cost for the conversion, and it is not cheap at all . I had a really clean black 996 coupe with a d chunked motor . There was just no way out. No matter how I penned it out all the scenarios , I was spending just about what I could purchase a running example for plus a metric ton of labor . I sold it as is , and I love a good project . I have to really love something to go upside down on it . A 996 cab would not make that list . |
"He did the clutch recently and did the IMS bearing upgrade. He took it to his local service guy in Walnut Creek who can only say it’s toast"
I'm missing a lot of story here. WHY did you go to the local service guy Just for maintenance job or did it have some symptoms of a problem, if so "WHAT" symptoms And quite frankly, any body who says it's toast, should be able to explain "WHY" and "WHAT" the 20 K rebuild is going to do. You don't need a tear down to identify a D chunk , piston to valve contact This is 2020.. bore scopes are cheap these days Everybody is talking options or ideas on what to do with a dead engine.. but for all we know it's just a busted head gasket.. |
Car was serviced religiously at Valhalla in Lafayette, CA until they closed, then he switched to Pacific Power Motorsports in Walnut Creek, CA. He went to start it and it clunked, so had it towed in to PPM. The tow truck driver started it up and drove it on the flatbed, then PPM told him it had a broken chain. I wouldn’t think it would even run if a chain was broken. I don’t think they even diagnosed it properly, saying they wouldn’t know until the engine is out. Now the owner is being referred to a mechanic in Reno who will rebuild the engine for 12K and have the shop next door R&R the engine for $4K. Sounds bad to me in every regard. Any reputable shops near Walnut Creek for a quality second opinion?
If we are going to sit here and speculate then the IMS 'upgrade' could have been the problem. Sounds to me when it goes "chunk" that the timing chain jumped.
I would have been more than furious with the TT driver. Unless he was told that he could start and drive the car knowing it was being towed because of an engine issue, I would waste not a minute to sue the pants off that guy. And if that's the story and the new mechanic heard it too, I'm with him all the way. The motor is now toast thanks to the idiot that re-started it. You know, unless you're barreling down the road when disaster strikes, some parts can be saved. No, I'm not Jake Raby, but I'm not motormeister either. I'd buy a project like that for the right money. And, yes, I'd be throwing my labor out the window. |
The owner’s friend is bringing a trailer to take it to Reno, where the mechanic will inspect it before the engine comes out.
I agree with WTF on the tow truck driver starting it! |
did MotorMeister by any chance restart under new name?
I wouldn't even consider that. |
| All times are GMT -8. The time now is 03:43 PM. |
